I've accidentally deleted a workspace and was wondering if it's possible to recover it. We are running version 12 of PDMLink and version 7 of Creo
If the files were uploaded to the server and 'remove unreferenced files' hasn't been run yet, they should be available in the file vault folders as well. Finding them can be tricky, but not impossible.
The deleted workspace is not possible to recover in Windchill.
You can be lucky and there could be local files with last modifications from Creo.
You can use WC File Recovery to try pickup creo files from local cache.
The case CS104751 describes how to use it.
PetrH
