Thanks to previous posts in this forum, I learned how to use the "Load From File" utility to bulk-add additional rules in the Policy Administrator. I also noted (again, as described here), that I can't over-write or revise existing rules already in the system.
My question this morning is; Is there a utility or method available to bulk-delete all of the existing rules that I want to change?
If not, then I am faced with deleting themmanually on each of our Products before bulk-loading the new rules, and at that point, I sort of lose the advantage a bulk-loading script offers in the first place.
Thanks in advance for any advice you might share,
Steve
It seems I may have stumped the forum, so I'll try a different question.
If a policy is undefined (i.e.: Permissions are neither granted or denied), how does PDMLink respond?
Does the system default to "Grant" or "Deny"?
Thanks for any light you might shed on this for me!
Steve
Thanks Dave and Jason!
I'm going to try to wade through Jason's code, since it appears to be the cleaner solution. However given my nascent java skills, I may fall back on Dave's solution since I understand it better.
Thanks again!
