I have created a Part with design view, which is having revision -.1
Then I have created a manufacturing view of same part, it has revision -.-.1 , which should be same as design view.
Further, I independently created a part with manufacturing view, it has a correct revision -.1
I am working this same conversion in my system. Linking my post:
Note that the conversion tool has been deprecated in the current version.
Hi @K_Patil
The behavior is old multilevel revision schema. Your system has been upgraded from previous version where the multilevel revision schema was a standard.
In new versions 10.0+ a single revision schema is used.
Your actual behavior is normal if the system is not converted to new single revision schema usage.
Following article describes your situatiuon
CS79141 - Why new containers still use the the old multi-level versioning schema
Hope this can help you.
PetrH
