Did Similar User go away in WC10.0?
Bucknut
7-Bedrock
In WC PDMLink 9... I could create new users by 'copying' them by choosing the similar to function within the edit user window. Now in 10.0 I don't find that ability. Has it been removed or am I just over looking something? The online documentation hasn't been helpful on this subject either. Just saying.
Any assistance would be appreciated.
7 REPLIES 7
right click
Darren,
Thanks for the quick response but as you can see in the picture below the Save As line is not present. I believe I'll contact my VAR to find out what's up as they do our installs.
Unless you know how I can turn on this function....
Mark
"Save As New User" was available in WC 10.1 as of M020. I do not have access to a WC 10.0 system. Did you check the WC help for any additional infomation within your WC 10.0 system? I don't remember this functionality being availalbe in WC 10.0 M030.
Save As New User was added in 10.0 M050. See p. 21 of the Changes For This Release document:
http://support.ptc.com/WCMS/files/122226/en/WCChangesForThisRelease.pdf
Thanks Lori & Michael.
So if it was included in 10.0 M050 why doesn't it work in 10.1 M050?????? Did they remove it again? There is a help page but what it says does not work. There is NO right click point that brings up a "Save As New User" option. Line one of the Saving As a New User states: "Select Save As New User from the right-click actions menu of an existing user within the Participant Administration table." Right click actions menu? If that means to right click on the actions pull down why doesn't it say that? But even so all that happens is a standard windows set of options. If you place the cursor over an existing user and right click you get a No Actions to Display message.
PTC is so frustrating.
Moving on.......
LoriSood
23-Emerald I
(To:Bucknut)
I am able to do a Save As New User in 10.1 M050:
What kind of user are you logged in as? Site admin?
