I want to use a distributed database system for my Windchill PDMLink 10.0 .
Any suggestion how to configure it.
Can you please explain what do you mean by "distributed database system" ?
Distributed Database system means, one have one Windchill server but it will be connecting to 2 or moe database server.
This is costly but performance and relaibility is very good.
Hi Sabyasachi,
As Windchill use Oracle or Sql Database.
As per my Knowledge, one instance of Windchill communicate with only one Database Instance.
In simple, one Windchill, one databse.
Vivek
Hello Vivek,
What you told is right , but I mean 2 diffrent database server of same type (Oracle or Sql).
If this implementation is possible then the performance will increase , so atleast users won't get irritation.
This is possible but not sure how to implement in Windchill, because during instasllation in won't ask for multiple DB as that of FCS.
Onr more thing I think while installing the DB it will ask you whether you want to install it as a single one or cluster one. SO if we installed the DB as cluster and then while installing Windchill if we point it to that DB (main server) then I guess it will use. BUt not sure
Thanks.
Sabyasachi
