Hi Windchillers,
Iam trying to download the latest copy of EPM document by using the following code; but the content downloaded is non latest. What could be the issue :
package com.phoenix.listen;
import wt.content.ApplicationData;
import wt.content.ContentHelper;
import wt.content.ContentItem;
import wt.content.ContentServerHelper;
import wt.content.FormatContentHolder;
import wt.epm.EPMDocument;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.util.WTException;
public class EPM_Doc_Pass {
public static boolean downloadFile(EPMDocument epmDoc, String downloadDirectory) {
boolean result=false;
ContentItem primaryContent=null;
String wtTemp = System.getProperty("wt.temp");
String fullName = wtTemp + "//" + downloadDirectory + "//" + epmDoc.getCADName();
String Docname = epmDoc.getName();
try {
// EPMDocument
if ( !epmDoc.isGeneric() ) {
QuerySpec qs = new QuerySpec (EPMDocument.class);
qs.appendWhere(new SearchCondition(EPMDocument.class,EPMDocument.NAME,SearchCondition.LIKE,Docname));
qs.appendAnd();
qs.appendSearchCondition (new SearchCondition (EPMDocument.class, "iterationInfo.latest", SearchCondition.IS_TRUE));
QueryResult qr = PersistenceHelper.manager.find(qs);
while (qr.hasMoreElements()) {
EPMDocument epmDoc1= (EPMDocument)qr.nextElement();
System.out.println(epmDoc1.getCADName()+ epmDoc1.getVersionDisplayIdentifier()+epmDoc1.getIterationDisplayIdentifier());
epmDoc1 = (EPMDocument) ContentHelper.service.getContents( epmDoc1 );
primaryContent = ContentHelper.getPrimary((FormatContentHolder)epmDoc1);
if ( primaryContent!=null )
System.out.println("downloadFile >>> EPMDocument, writeContentStream : " + fullName );
ContentServerHelper.service.writeContentStream( (ApplicationData)primaryContent, fullName );
result=true;
catch (Exception _e) {
_e.printStackTrace();
return false;
System.out.println("downloadFile >>> OUT...");
return(result);
My thinking is that your query is getting the latest iteration of each version. If it's me I'm probably querying for EPMDocumentMaster and getting the ordered list of versions (allVersionsOf()) from there
Just looking at other download samples, should this:
qs.appendAnd();
Be this:
qs.appendWhere(new SearchCondition(EPMDocument.class,EPMDocument.NAME,SearchCondition.LIKE, Docname));
qs.appendAnd();
qs.appendWhere(new SearchCondition(EPMDocument.class, "iterationInfo.latest", "TRUE"));
Can you replace downloadFile method with following method and try? I have not tested this code, but it should work. I guess this is what Keir Pritchard suggested.
try {
// EPMDocument
QueryResult epmQueryResult = VersionControlHelper.service.allVersionsOf(epmDoc.getMaster());
EPMDocument epmDoc1 = null;
while(epmQueryResult.hasMoreElements()){
epmDoc1 = (EPMDocument) epmQueryResult.nextElement();
break;
if(primaryContent!=null){
ContentServerHelper.service.writeContentStream((ApplicationData)primaryContent, fullName);
result=true;
} catch (Exception _e) {
return false;
return(result);
Hi
Please Try the following code,
package ext.test;
import wt.epm.EPMDocumentMaster;
import wt.pds.StatementSpec;
public class EPMLatest {
public static void main(String[] args) throws WTException {
// Retrieve List of EPMDocumentMasters
QuerySpec qs = new QuerySpec(EPMDocumentMaster.class);
EPMDocumentMaster master = null;
QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
System.out.println("Number of EPM Document Masters: " + qr.size() + "\n\n");
master = (EPMDocumentMaster) qr.nextElement();
System.out.println("***** Name ->"+ master.getName());
EPMDocument latest = (EPMDocument)wt.vc.VersionControlHelper.service.allVersionsOf(master).nextElement();
String versionLatest = wt.vc.VersionControlHelper.getVersionIdentifier(latest).getValue();
System.out.println("******** Identity -> "+ latest.getIdentity());
System.out.println("******** Latest Version -> "+ versionLatest);
System.out.println("******** Latest Iteration -> "+ latest.getIterationDisplayIdentifier());
System.out.println("******** State of latest version of latest iteration -> "+latest.getState());
// Use Here to download the Content
primaryContent = ContentHelper.getPrimary((FormatContentHolder)latest);
ContentServerHelper.service.writeContentStream( (ApplicationData)primaryContent, FileFullName(C:/abc.prt) );
BR
MKR
