Hi Fellows,
When I use the "Download documents to compressed file" on a search result I only get the Primary contents.
Is it also possible to download the attachments?
I'm working on Windchill PDMLink 10.1 M040.
Any answer is welcome
Thanks.
Yes, today it only includes the primary contents, but I like the idea of optionally downloading all the attachements too. If you don't mind, please submit this as a Product Idea
Thank you for your answer, I feared so...
Is it just possible to move the discussion? If not I'd like to submit the idea but I don't know where (I'm still a rookie here )
How we can download multiple documents from windchill 9.1.?
Chirag
Only two ways that I know of, but this works perfectly - have used many times.
1. Create a new document. Go to Structure, Add all documents that need to be downloaded under it. From the new document select download all selected.
2. Add all documents to a Project. From Project Details, select to download the entire project.
Mike,
Thanks for the answer.
But how to move documents back to the original localtion if we add in to project.
Chirag
