Editable field in WTpart structure attributes
FC_9723361
9-Granite
Version: Windchill 13.0
Use Case: List of soft type editable
Description:
Hello, some one knows how to create 1 or more attributes editable to insert in structure wtpart or similar.
For example i would like to insert "weight"
in this page
7 REPLIES 7
Try the steps in this article: What are the steps needed in order to update the "weight" on a wt.part with the value from the corresponding CAD document?
https://www.ptc.com/en/support/article/CS20049
No, should be free fillable directly from Windchill
So you just want an additional attribute that is not mapped to anything? Have you tried:
Site level Type and Attribute management
1. Create a resuable attribute
2. Select the Part object type -> Create a new attribute (type of global), select the resuable attribute that was created.
Yes just done.
But WTPart -> structure page is not editable. (only just if i check-out and modify).
Is there a way to edit it without checking out?
No.. you have to checkout the WTPart in order to make edits. This is one of the core functions of Windchill. so that changes are tracked.
ok, but is possible after checkout implement OOTB a grid with fillable soft type? for example in info page or attribute page?
or i must use edit and checkout in a new frame?
You can do inline editing when in a structure view. See: https://support.ptc.com/help/wnc/r11.2.1.0/en/index.html#page/Windchill_Help_Center/NewandChanged_11_2_10_PSBInlineEditing.html
Make sure that the preference is enabled: https://www.ptc.com/en/support/article/CS375084?source=search
Example:
