Effect Redline Notice on System Configuration and Upgrades
rohanPDSVISION
Version: Windchill 12.1
Use Case: Versioning Explodes and series alignment is corrupted
Description:
While doing our deployment build we came across this issue. When a Redline Notice is created, this is pushing new version Seeds in this system. e.g 'CHG-AA-1'. This 'CHG-' comes from a preference. the AA-1 is taken up from the version of the Affected Item. This although programmatically created OOTB by Windchill , is directly pushed into the versionida2versioninfo column of the WTPart.  The ill effect of this is, when we load our next build we get 'Seed CHG-AA-1' is not available in the HarvardSeries error. We have to put in this seed value as a legacy tag to get around the issue. By continuing to do so, Over the time, the  series will explode and get populated with a lot of Junk values just to support Redline.
Q-
1. The best I can do today is get rid of the CHG- prefix, what about the AA-1
how is this handled to make it seamless in the configuration, right now its chaos, every build we will now have to push unnecessary versions in our series?
Hi @rohanPDSVISION,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
