Hi @AC_8227635
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
What is a good question?
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Thank you for your reply.
Can you describe the current configuration of your Windchill DS password policy? Are you currently using the default Salted SHA-1 encryption algorithm?
Yes, the current configuration uses the default password policy of Windchill DS, and it is set to use the default Salted SHA-1 encryption algorithm.
Are you concerned that changing the encryption algorithm to Salted SHA-256 might affect existing users and their data? If so, what specific impacts are you worried about?
I’m concerned that it might cause user password verification failures or require users to reset their passwords.
Hi @AC_8227635,
If so, please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Translation did not work so ran through Google: The default password policy of Windchill DS uses Salted SHA-1 (ds-cfg-default-password-storage-scheme). If I want to change to another encryption algorithm (such as Salted SHA-256), what will be the impact on the current users of the system? Does the manufacturer support changing the Windchill DS encryption algorithm midway when there are users and data?
I would think that this would not matter but certainly worth a test. I found this write up the has a lot of good information: https://backstage.forgerock.com/docs/ds/8/use-cases/change-password-storage.html
OpenDJ is the tool behind WindchillDS.
