Hi
i get error when compiling java files in eclipse. I am exporting the correct jar files in eclipse, but i get error.
please tell me that where i am doing wrong.
what is the meaning of "indirectly referenced from required .class files" ?
Thank you
VIJAYAN
Make sure you have the WT_HOME/srclib/tool/Annotations.jar in your project classpath for the classes you list above.
The phrase "indirectly referenced" means you have some class in your project (e.g. you are working on Class A) and it refers to another class from some jar (e.g. your class A uses class B) and that other class refers to a third class which you don't use in your class (e.g. your Class A uses Class B which uses Class C so you are "indirectly" referencing class C).
Make sure that all the PTC jars are included in your project's runtime. This should fix the problem.
Keep in mind that it won't necessarily fix the problem. I haven't looked at these classes in particular, so I can't say for sure. It's possible to compile a class that references another class, then remove the other class from your package, and never call the method that references the removed class.
OracleTableSize and Cardinality is actually enum
