I have a tree as shown in the figure and I have to write a DataUtility class for a particular column, say Column "Name".
How to get the Parent oid of an object in the Table?
NmHTMLTableNode node = new NmHTMLTableNode (object);
is not giving the null value for
node.getParent();
node.getRoot() is returning the same oid object.
There is no link(PartUsage link or Any OOTB link) between the parent and child nodes.
Have any ideas?
Thanks in advance ....
helo folks,
yup..I gotta answer..But I do not know whether it is correct way of finding the node.....
ModelContext.getModelObjects() will give you the list objects in that node (node object +child node objects) in array... when you expand a particular node...
ModelContext.getModelObjects() will return the list of nodes and its child objects in a list when you expand the whole tree
we have to filter the node that we need for our child object from this list.
