Hi All,
I wanted to change the default baseDN i.e o=ptc to o=ptc1. For the same i have taken the export of existing ldif configuration and changed the entry o=ptc to o=ptc1. In WDS, i made a new baseDN with o=ptc1 and exported the new .ldif file to this baseDN.
From Windchill i have modified the property from site.xconf "ie.ldap.propertyBaseDn" and also from Apache changed two filesnamely "app-Windchill-Auth.conf" and "app-Windchill-AuthProvider.xml".
When i start Windchill i get the following error "Cannot process participant Administrators because a related disconnected participant wt.org.WTGroup:15 exists in the database". When i went into wtgroups table, the Administrators group has the repairneeded flag as 1.
I manually tried to update the field repairneeded to 0, but this did not help.
Can anyone share their experiences if you have faced similar situation.
Karan Narang
