Error while changing baseDN in Windchill DS
karan1904
Hi All,
I wanted to change the default baseDN i.e o=ptc to o=ptc1. For the same i have taken the export of existing ldif configuration and changed the entry o=ptc to o=ptc1. In WDS, i made a new baseDN with o=ptc1 and exported the new .ldif file to this baseDN.
From Windchill i have modified the property from site.xconf "ie.ldap.propertyBaseDn" and also from Apache changed two filesnamely "app-Windchill-Auth.conf" and "app-Windchill-AuthProvider.xml".
When i start Windchill i get the following error "Cannot process participant Administrators because a related disconnected participant wt.org.WTGroup:15 exists in the database". When i went into wtgroups table, the Administrators group has the repairneeded flag as 1.
I manually tried to update the field repairneeded to 0, but this did not help.
Can anyone share their experiences if you have faced similar situation.
Karan Narang
Run WinDu. It might help if you haven't FUBAR'ed the system. Sounds like
you did not update the database table correctly.
