Error you do not have access to this object
11025060
avillanueva
23-Emerald I
(To:11025060)
Sounds like a compilation problem. What parts were customized?
https://www.ptc.com/en/support/article/CS382596?source=search
Found this similar article.
5 REPLIES 5
The reasons causing the error could be several.
In your case one is described in this article.
"You do not have access to this object or it does not exist" occurs when the user click the task link in the email notification for the workflow task
The object you do not have access to may also have been deleted.
Marco
avillanueva
23-Emerald I
(To:11025060)
Yes @avillanueva it was a compilation issue as you mentioned. I figured it out and fixed it. Thank you.
Hi @11025060,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
How is this post the solution? @11025060, you can write your own summary if none of the others fit.
