Are you able to export specified info from a Promotion Request as a report.
Ie, Process Name, Description, Promotion Objects. Promotion Status etc
I have created a tab with all the required info, but other than doing a screen-dump, im falling short.
It would be usefull to do this as to send this to external sources rather than type all the info out again.
Possibly as a DXF ( same kind of thing as when you can export search results) as a .csv???
Adam
Windchill 10.2
IE11
as a PDF not DXF ???
