Export all data into 1 excel sheet
BWS
I have thousands of Windchill parts saved in multiple folders in Windchill. In these folders I am able to see
columns with weight, thickness, material and other information about these parts.
I would like to know if there is an easy way to export every single part of all folders and subfolders into 1 excel sheet, with the same columns as I get in the folders.
Thanks in advance!
Marco_Tosin
(To:BWS)
You should use a report to extract all metadata.
If you don't know how to build a report, take a look at this document https://community.ptc.com/t5/Windchill-Questions/Resource-for-reporting/td-p/448738
In it there are lots of report ready to use for your convenience.
Marco
BenLoosli
(To:BWS)
If you can get a view that spans all folders, then yes, but I don't think that is possible.
Your best option is to export the information per folder into excel sheets, then cut and paste the rows into a single master spreadsheet. I do the something like this with my family table data.
