Export to spreadsheet
ptc-6034002
Hello
Does anybody know, how can I add more attributes to BOM report?
I have one Product Structure and after export reports to Excel, inside BOMSheet I have only default attributes, like Action, Level, View, Number or Type.
How can I put more attributes to BOMSheet?
BjoernRueegg
(To:KD)
If you would like to add some more usage attributes, it's unfortunately not possible to add them within the GUI. You need to extend the MultiLevelBOMReportTreeBuilder class and this needs some programming know-how. This is also described in the customization guide.
I would support this idea to configure this within the GUI!
5 REPLIES 5
LoriSood
23-Emerald I
(To:ptc-6034002)
The following article may be useful here:
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS131127
BenPerry
(To:LoriSood)
I'm getting an error here.
Error: Document 131127 is not customer viewable as it is an internal PTC document.
Hi Lori
Thank you for information about similar case, but link to case doesn't work. I received this same error like Ben.
KD
(To:ptc-6034002)
Not sure which Windchill version you are using but in 10.1 M040 you can customize the view to add more attribute.
Kaushik
BjoernRueegg
(To:KD)
