Extract multi-level bom with a query
EMore
Hello to everyone,
I need to create a query that extract a multi-level Bom based on a specified Number, Version and View (manufacturing/design).
The query that i made, take the latest version of the childs, but i need the "as stored" configuration of that bom in that specific version and view.
I have tried usign Query Builder, but it can extract only Single-level Bom.
I leave at the bottom the query i made
Can someone help me?
Thanks for your support
Best regards.
"WITH
    LastVersion
    AS
        (SELECT *
           FROM (SELECT p.*,
                        ROW_NUMBER ()
                            OVER (
                                PARTITION BY p.ida3MasterReference
                                ORDER BY
                                    TO_NUMBER (p.VERSIONIDA2VERSIONINFO) DESC,
                                    TO_NUMBER (p.ITERATIONIDA2ITERATIONINFO) DESC)    AS rn
                   FROM WTORACLE.WTPart p)
          WHERE rn = 1),
    BOM_Recursive (part_id,
                   codice,
                   descrizione,
                   ida2a2,
                   padre_id,
                   Revisione,
                   Iterazione,
                   Revisione_Completa,
                   Stato_Figlio,
                   livello,
                   VALUE,
                   GatheringPart)
    AS
        (-- Root specifica
         SELECT p.ida2a2                                          AS part_id,
                pm.WTPARTNUMBER                                   AS codice,
                pm.name                                           AS descrizione,
                pm.ida2a2,
                NULL                                              AS padre_id,
                p.VERSIONIDA2VERSIONINFO                          AS Revisione,
                p.ITERATIONIDA2ITERATIONINFO                      AS Iterazione,
                || p.ITERATIONIDA2ITERATIONINFO                   AS Revisione_Completa,
                p.STATESTATE                                      AS Stato_Figlio,
                0                                                 AS livello,
                ECL.VALUE,
                DECODE (pm.hidePartInStructure, 0, 'NO', 'SI')    AS GatheringPart
                JOIN WTORACLE.WTPartMaster pm
                    ON p.ida3MasterReference = pm.ida2a2
                LEFT JOIN
                (SELECT sv.*
                   FROM WTORACLE.StringValue  sv
                        JOIN WTORACLE.StringDefinition sd
                            ON sd.idA2A2 = sv.ida3a6
                  WHERE sd.name = 'ECLASS') ECL
                    ON p.idA2A2 = ECL.ida3a4
          WHERE     pm.WTPARTNUMBER = 'C310272AD01F01'
                AND p.VERSIONIDA2VERSIONINFO = '05'
                AND p.ITERATIONIDA2ITERATIONINFO = '4'
         UNION ALL
         SELECT lv.ida2a2                                         AS part_id,
                cm.WTPARTNUMBER                                   AS codice,
                cm.name                                           AS descrizione,
                cm.ida2a2,
                br.part_id                                        AS padre_id,
                lv.VERSIONIDA2VERSIONINFO                         AS Revisione,
                lv.ITERATIONIDA2ITERATIONINFO                     AS Iterazione,
                || lv.ITERATIONIDA2ITERATIONINFO                  AS Revisione_Completa,
                lv.STATESTATE                                     AS Stato_Figlio,
                br.livello + 1                                    AS livello,
                ECL.VALUE,
                DECODE (cm.hidePartInStructure, 0, 'NO', 'SI')    AS GatheringPart
           FROM BOM_Recursive  br
                JOIN WTORACLE.WTPartUsageLink u ON u.ida3a5 = br.part_id
                JOIN WTORACLE.WTPartMaster cm ON cm.ida2a2 = u.ida3b5
                JOIN LastVersion lv ON lv.ida3MasterReference = cm.ida2a2
                LEFT JOIN
                (SELECT sv.*
                    ON lv.idA2A2 = ECL.ida3a4)
  SELECT part_id      AS Padre_id,
         codice,
         descrizione,
         padre_id     AS Figlio_id,
         Revisione,
         Iterazione,
         Revisione_Completa,
         Stato_Figlio,
         livello,
         VALUE        AS eclass,
         GatheringPart
    FROM BOM_Recursive
ORDER BY livello, codice;"
HelesicPetr
(To:EMore)
Hi @EMore
The Query Builder can not call recursively an another report so you can not get the multilevel bom just by the Query Builder.
Why do you not use the Structure BOM Report? it can generate the multilevel BOM with attributes you need.
Otherwise you have to write own function to generate BOM as you need with recursive function.
PS> as stored configuration for WTPart does not exist. So you have to play with the modification time and it is really too complicated.
PetrH
