Facing issue while getting Business Attribute of a WTpart by using NEW_VERSION event
vuchekar
Hi All,
My requirement -> fetch a Business Attributes of WTPart, just after the WTPart creation.
for this purpose, i am using this event " VersionControlServiceEvent.NEW_VERSION ".
i am able to get part Name,number, creator, timestamp etc here, but when i try to fetch Business Attributes, its gives value null, even there a business attribute present with valid values.
Here is My code, Please let me know where i am doing wrong ?
Any help will be great !!
1. VersionEventListenerAdapter.java
package ext;
import wt.epm.EPMDocument;
import wt.events.KeyedEvent;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.fc.ReferenceFactory;
import wt.fc.WTReference;
import wt.part.WTPart;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.services.ServiceEventListenerAdapter;
import wt.util.WTException;
import wt.util.WTPropertyVetoException;
import wt.vc.VersionControlServiceEvent;
public class VersionEventListenerAdapter extends ServiceEventListenerAdapter {
  public VersionEventListenerAdapter(String serviceId) {
     super(serviceId);
  public void notifyVetoableEvent(Object event) throws WTException, WTPropertyVetoException {
     if (!(event instanceof KeyedEvent)) {
         return;
     Object target = ((KeyedEvent) event).getEventTarget();
     Object eventType = ((KeyedEvent) event).getEventType();
     System.out.println("FROM @@@@@@@@@  Target >>>>> "+target);
     System.out.println("FROM @@@@@@@@@  eventType >>>>> "+eventType);
     ReferenceFactory refFactory = new ReferenceFactory();
  WTReference ref = refFactory.getReference(target.toString());
     if (eventType.equals(VersionControlServiceEvent.NEW_VERSION))
        /** Call your business code here
            example : yourMethod(target);
      System.out.println(">>>>>>>> INSIDE EVENT TYPE >>>> ");
      if(target instanceof WTPart){
      WTPart wtp = (WTPart)ref.getObject();
      System.out.println("Name >> "+wtp.getName());
      System.out.println("Number >> "+wtp.getNumber());
      System.out.println("Created By >> "+wtp.getCreatorFullName());
      System.out.println("Creation Time >> "+wtp.getCreateTimestamp());
      System.out.println("Time >>> "+System.currentTimeMillis());
      System.out.println(" VERSION >> "+wtp.getVersionIdentifier().getValue()+"."+wtp.getIterationIdentifier().getValue());
      System.out.println("======= =================");
     // below code to fetch attribute GOB_WEIGHT
      com.ptc.core.lwc.server.LWCNormalizedObject obj = new com.ptc.core.lwc.server.LWCNormalizedObject(wtp, null,
             java.util.Locale.US, new com.ptc.core.meta.common.DisplayOperationIdentifier());
      obj.load("GOB_WEIGHT");
      java.lang.String string_value = (java.lang.String) obj.get("GOB_WEIGHT");
      System.out.println("Soft attibute value : " + string_value);
2. MStandardListenerService.java
package ext;
import wt.services.ManagerException;
import wt.services.StandardManager;
public class MStandardListenerService extends StandardManager implements MListenerServiceInterface {
  private static final long serialVersionUID = 1L;
  protected synchronized void performStartupProcess() throws ManagerException {
     VersionEventListenerAdapter versionEventListenerAdapter = new VersionEventListenerAdapter(getName());
     getManagerService().addEventListener(versionEventListenerAdapter, VersionControlServiceEvent.generateEventKey(VersionControlServiceEvent.NEW_VERSION));
     getManagerService().addEventListener(versionEventListenerAdapter, VersionControlServiceEvent.generateEventKey(VersionControlServiceEvent.PRE_NEW_VERSION));
     getManagerService().addEventListener(versionEventListenerAdapter, VersionControlServiceEvent.generateEventKey(VersionControlServiceEvent.POST_INSERT_ITERATION));
     getManagerService().addEventListener(versionEventListenerAdapter, VersionControlServiceEvent.generateEventKey(VersionControlServiceEvent.POST_ROLLUP));
     getManagerService().addEventListener(versionEventListenerAdapter, VersionControlServiceEvent.generateEventKey(VersionControlServiceEvent.POST_SUPERSEDE));
  public static MStandardListenerService newMStandardListenerService() throws WTException {
     MStandardListenerService instance = new MStandardListenerService();
     instance.initialize();
     return instance;
Please check and suggest me.
Vivek
Hi Vivek,
A quick test at my end shows the events are fired in following sequence. So when you listen to NEW_VERSION event the IBA's are not yet persisted in the database and hence the value is still NULL. Try POST_STORE event instead.
/wt.vc.VersionControlServiceEvent/NEW_VERSION   :: for object wt.part.WTPart
/wt.fc.PersistenceManagerEvent/INSERT :: for object wt.iba.value.StringValue
/wt.fc.PersistenceManagerEvent/POST_STORE :: for object wt.part.WTPart
Bhushan
Hi Vivek,
Bhushan
Thanks, Bhushan.
By using POST_STORE  event, now i am able to get attributes on that part.
Thanks a lot.
Vivek
