First Pass Yield RATIO for Change Reqeusts
AAgrawal_92
6-Contributor
I am trying to create a count function that counts the number of ECRs for which atleast one work item was given a 'Rework' vote, that way I can count how many ECRs were reworked atleast once and then divide that by total ECRs.
first pass yield = 1- (ECRs reworked atleast once/Total number of ECRs)
The problem I am facing is because the ECR is linked to work item as a PBO, the counts of ECRs is including each work item of a given ECR where the Rework vote was given.
Also, calculating this ratio seems almost impossible.
Do we need to just download the data and do the calculation in an external tool?
rleir
(To:AAgrawal_92)
Have a look at the 'trip count' field. It can get incremented in a workflow when you loop back to an earlier state. This does not answer your question directly, but might be useful.
Careful what you wish for. I created this sql query to calculate turnbacks (part of QCPC in lean manufacturing). In this case, I was assigning turnbacks to days late of a process set with a defined duration. This also was from earlier Windchill version so schema might have changed. I had to handle what if the process was sent back around? How do we account for that? At this time, we dinged them for the entire loop back. Since then we do not so this was no longer needed. I had no hope of doing this in Query Builder. I ran in my SQL editor and downloaded to Excel. The result of this query was the number of turnbacks per "step or phase" in the review workflow.
SELECT TABEC.ECN, TABEC.RESOLUTIONDATE, TABHOLD.TURNBACK HOLD_TASK_TB, TABCCBR.TURNBACK CCB_REVIEW_TB,
       TABCCBCD.TURNBACK CCB_CHAIRDECISION_TB, TABAMEND.TURNBACK AMEND_TB, TABFINAL.TURNBACK FINAL_REWORK_TB,
       TABAUDIT.TURNBACK CM_AUDIT_TB
FROM (SELECT DISTINCT M.WTCHGORDERNUMBER ECN, O.RESOLUTIONDATE
      FROM WTCHANGEORDER2 O, WTCHANGEORDER2MASTER M
      WHERE
      M.IDA2A2 = O.IDA3MASTERREFERENCE AND
      O.RESOLUTIONDATE >= TO_DATE('1/1/2019','MM/DD/YYYY') AND
      O.STATESTATE LIKE 'RELEASED') TABEC,
    (SELECT ECN,
        (CASE WHEN TOTAL_TRIPS = 1
         THEN TURNBACK
         ELSE
            (CASE WHEN MAX(FIRSTPASS)<3
             THEN ROUND((TOTAL_TRIPS-1)+ SUM(LOOPS)+0.5)
             ELSE ROUND(MAX(FIRSTPASS)-3+(TOTAL_TRIPS-1)+ SUM(LOOPS)+0.5)
             END)
         END) TURNBACK
        FROM
        (SELECT M.WTCHGORDERNUMBER ECN,
        (CASE WHEN (AA.DEADLINE-AA.CREATESTAMPA2)<3
         THEN (CASE WHEN ((AA.ENDTIME-AA.CREATESTAMPA2)-3)<0 THEN 0
               ELSE ROUND(((AA.ENDTIME-AA.CREATESTAMPA2)-3)+0.5)
               END)
         ELSE
                (CASE WHEN (AA.ENDTIME-AA.DEADLINE)<0 THEN 0
                ELSE ROUND(AA.ENDTIME-AA.DEADLINE+0.5)
                END)
         END) TURNBACK, AA.DEADLINE,AA.TRIPCOUNT TOTAL_TRIPS,  (W1.MODIFYSTAMPA2-W1.CREATESTAMPA2) FIRSTPASS,
         TEMP1.MODIFYSTAMPA2-TEMP1.CREATESTAMPA2 LOOPS
        FROM WTCHANGEORDER2 O, WFPROCESS WFP, WFASSIGNEDACTIVITY AA,WTCHANGEORDER2MASTER M,
        (SELECT A2.IDA3A4,W2.MODIFYSTAMPA2, W2.CREATESTAMPA2
         FROM WFASSIGNMENT A2, WORKITEM W2
         WHERE
         W2.IDA3C4  = A2.IDA2A2 AND
         A2.TRIPCOUNT > 1 ) TEMP1, WFASSIGNMENT A1, WORKITEM W1
        WHERE
        WFP.IDA2A2 = AA.IDA3PARENTPROCESSREF AND
        A1.IDA3A4  = AA.IDA2A2 AND
        TEMP1.IDA3A4 (+) = AA.IDA2A2 AND
        AA.NAME LIKE 'Hold%' AND
        O.STATESTATE LIKE 'RELEASED' AND
        WFP.BUSINESSOBJREFERENCE LIKE 'VR:wt.change2.WTChangeOrder2%' AND
        O.BRANCHIDITERATIONINFO = TO_NUMBER(SUBSTR(WFP.BUSINESSOBJREFERENCE,30)) AND
        W1.IDA3C4 = A1.IDA2A2 AND
        A1.TRIPCOUNT = 1) TEMP
        GROUP BY ECN, TURNBACK, DEADLINE, TOTAL_TRIPS) TABHOLD,
     (SELECT ECN, TURNBACK, DEADLINE,TOTAL_TRIPS,FIRSTPASS, SUM(LOOPS) LOOPS
        FROM
        (SELECT ECN, TURNBACK, DEADLINE,TOTAL_TRIPS, MAX(FIRSTPASS) FIRSTPASS, AA_TRIP, MAX(LOOPS) LOOPS
        FROM
        (CASE WHEN (AA.DEADLINE-AA.CREATESTAMPA2)<7
         THEN (CASE WHEN ((AA.ENDTIME-AA.CREATESTAMPA2)-7)<0 THEN 0
               ELSE ROUND(((AA.ENDTIME-AA.CREATESTAMPA2)-7)+0.5)
               END)
         ELSE
                END)
         AA.TRIPCOUNT AA_TRIP, TEMP1.MODIFYSTAMPA2-TEMP1.CREATESTAMPA2 LOOPS
         WHERE
        WHERE
        AA.NAME LIKE 'CCB Review' AND
        A1.TRIPCOUNT = 1)
        GROUP BY ECN, TURNBACK, DEADLINE,TOTAL_TRIPS, AA_TRIP)
        GROUP BY ECN, TURNBACK, DEADLINE,TOTAL_TRIPS, FIRSTPASS) TABCCBR,
     (SELECT ECN,
         THEN TURNBACK
         ELSE
            (CASE WHEN MAX(FIRSTPASS)<1
             ELSE ROUND(MAX(FIRSTPASS)-1+(TOTAL_TRIPS-1)+ SUM(LOOPS)+0.5)
             END)
         END) TURNBACK
        FROM
        (CASE WHEN (AA.DEADLINE-AA.CREATESTAMPA2)<1
         THEN (CASE WHEN ((AA.ENDTIME-AA.CREATESTAMPA2)-1)<0 THEN 0
               ELSE ROUND(((AA.ENDTIME-AA.CREATESTAMPA2)-1)+0.5)
               END)
         ELSE
                END)
         WHERE
        WHERE
        AA.NAME LIKE 'CCB Chairperson Decision' AND
        GROUP BY ECN, TURNBACK, DEADLINE, TOTAL_TRIPS) TABCCBCD,
        (SELECT ECN,
         THEN ROUND(TURNBACK+0.5)
         ELSE
         END) TURNBACK
        FROM
      (SELECT M.WTCHGORDERNUMBER ECN,(AA.ENDTIME-AA.CREATESTAMPA2) TURNBACK, AA.DEADLINE,AA.TRIPCOUNT TOTAL_TRIPS,
      (W1.MODIFYSTAMPA2-W1.CREATESTAMPA2) FIRSTPASS, TEMP1.MODIFYSTAMPA2-TEMP1.CREATESTAMPA2 LOOPS
         WHERE
        WHERE
        AA.NAME LIKE 'Amend%' AND
        GROUP BY ECN, TURNBACK, DEADLINE, TOTAL_TRIPS) TABAMEND,
     (SELECT ECN,
         THEN TURNBACK
         ELSE
             END)
         END) TURNBACK
        FROM
        (CASE WHEN ((AA.DEADLINE IS NULL) OR (AA.DEADLINE-AA.CREATESTAMPA2)<1)
               END)
         ELSE
                END)
         WHERE
        WHERE
        (AA.NAME LIKE 'Finalize%' OR AA.NAME LIKE 'Rework%') AND
        GROUP BY ECN, TURNBACK, DEADLINE, TOTAL_TRIPS) TABFINAL,
     (SELECT ECN,
         THEN TURNBACK
         ELSE
             END)
         END) TURNBACK
        FROM
               END)
         ELSE
                END)
         WHERE
        WHERE
        AA.NAME LIKE 'Audit EC' AND
        GROUP BY ECN, TURNBACK, DEADLINE, TOTAL_TRIPS) TABAUDIT
WHERE
TABEC.ECN=TABHOLD.ECN (+) AND
TABEC.ECN=TABCCBR.ECN AND
TABEC.ECN=TABCCBCD.ECN AND
TABEC.ECN=TABAMEND.ECN (+) AND
TABEC.ECN=TABFINAL.ECN (+) AND
TABEC.ECN=TABAUDIT.ECN
