Generate representation for STEP file for WTDocuments
apatil-2
I am attaching STEP and IGS files as a primary content to WTDocument. I want to generate the representations.
I have added.
worker..DWG=DUMMY,preconverted=true
worker..TIF=DUMMY,preconverted=true
worker..BMP=DUMMY,preconverted=true
worker..PDF=DUMMY,preconverted=true
worker..STEP=DUMMY,preconverted=true
worker..IGS=DUMMY,preconverted=true
in wvs.properties file.
but not working.
please suggest.
TomU
(To:apatil-2)
  • Are you sure you put them in the correct place?  The location of the wvs.properties file changed in 10.2.
  • Did you restart the server after making the changes?
  • Did you try re-publishing any of these files after making the change?
  • Do you have automatic publishing enabled for WTDocuments (typically on check-in)?
Simply creating these properties doesn't make the files automatically show up.  They still need to be run through the publisher after these properties are created.
Here is the exact syntax I used for our 10.2 system:
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DWG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DXF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PDF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..BMP=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..JPG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..TIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..GIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PVZ=DUMMY,type=zip,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..EDZ=DUMMY,type=zip,preconverted=true
xconfmanager -p
TomU
(To:apatil-2)
xconfmanager -p
apatil-2
(To:TomU)
Its working now. There was problem with object adapter.
