I am using creo parametric and windchill and I would like to open version C.10 (current version is C.15) and save it as newest one since I would like to "delete" previous checked in vesions.
I am trying to do it with a clean workspace and then - history - version C.10 - add to workspace but I keep getting version C.15 when the file opens up... Does anybody know how to solve it?
Thank you in advance,
You need to go to the detail page of CAD Document
Show history tab
Go to the detail page of the previous iteration what you need
In that iteration add it to the empty workspace
In the wizard set filter to the As Stored option
Then you should have the previous model in the workspace.
If not then you do some mistake or there is some wierd configuration
PetrH.
Hi @BC_10219589
Do you apply as stored filter if you add the previous iteration to the workspace?
Also you need to Allow checkout of non-latest iterations
Hope this can help.
PetrH
Thank you for your help, just tried what you mentioned and I didn't manage to bring old version into the workspace. Any other ideas?
Thank you.
Show history tab
PetrH.
