Need help to delete 2 instances from a family table.
see in the sreenshots attached, I want to delete the files P14007_...
For that, I have to delete the last version of the generic 501109.
But the system doesn't accept! see the message attached...
Laurent
Delete that part also whose number is showing in the error.
Kaushik
As showing in the image the version of the selected drw is 1.0. That menas it didn't iterate after creation.
So, In order to delete the latest version you have to delete that drw itself.
Kaushik
I 've deleted the drawing,
but it's this message:
Kaushik
iT works!
Thanks a lot
Laurent
Laurent,
Were the generic file 501109 and the instance files P14007_... checked in to Windchill? If so, what release of Windchill are you using, 9.1?
Can you explain the steps you followed?
Lee
