Version: Windchill 12.0
Use Case: I have a use case where a supplier role should not see what security labels are used. When I tried to give the supplier user only the Windchill Base (Does not have Security Label / IP Protection license), still that user can see that wizard step of "Set Security Label". I also did not find a Profile action for "Set Security Label", we only have "Edit Security Label"
Description:
Need a suitable solution approach
Not that this is an answer to your original question, but I am pretty sure that if you have security labels implemented, and Advanced as well as Base licenses, you are supposed to have a corresponding IP Protection license for each base license (1:1).
Supplier should create objects and not specify SLs ?
Hi Fadel,
Yes Supplier Role should not even see "Set Security Label" in the Wizard.
