12版本的Windchill,SolidWorks升级成2025版本
  • June 5, 2025
  • 420 views
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.0
目前我们使用的是12版本的Windchill,用户端需要将SolidWorks升级成2025版本,请问WGM集成是否支持。如果需要支持,有什么办法?
avillanueva
23-Emerald I
23-Emerald I
June 5, 2025
WGM is now release independent with Windchill somewhat. Here is more information on support.
https://www.ptc.com/en/support/article/CS242516?source=search
This has more info:
Windchill Workgroup Manager Software Compatibility Matrix
2025 is not supported until WGM 13.1.0.1 and this is supported with Windchill 12.1 so you should be good to upgrade. Don't forget about your CAD workers for publishing.
Community Moderator
June 12, 2025
Hello @KH_10695520
You have a response from our community champion. If it helped you solve your question, please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
