Hiding Attributes using OIR
Uthayan
Hiding Attributes using OIR for WTPart using hidden constraint doesnt work. All attributes are defined at Site level? Is there a way to achieve the same.
8 REPLIES 8
I don't know about hiding attributes with an OIR. Did you hide them with a constraint in the Type Manager? What constraint and value?
Hi Mathew,
I tried using the constraint " com.ptc.core.rule.server.impl.GetHiddenConstraint algorithm" in OIR.
Can we hide them using constraint in the Type Manager for Particular Org; wherein all the attributes are created in Site level.
It looks like the GetHiddenConstraint on the OIR should work but I haven't tested
Hi. You might want to look at http://communities.ptc.com/message/172231#172231
Are the attributes you are trying to hide modeled?
If they are attributes you created I think need to add them to you site.xconf to be able to hide them via the OIR.
Ex for our OIR we had to add:
<Property name="wt.change2.WTChangeRequest2" overridable="true"
targetFile="codebase/com/ptc/core/rule/server/delegate/init/RuleConfigurableTypeAttribute.properties" value="name,number,lifeCycle.id,lifeCycle,teamTemplate,teamTemplate.id,folder.id,organization.id,description,needDate,change_proposedChanges,theCategory,theComplexity"/>
Then you can use the OIR to hide them.
<AttrConstraint id="theComplexity" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetHiddenConstraint"/>
</AttrConstraint>
Thanks Mathew for your suggestion..Let me try the same and let you know.
Hi Mathew,
I got the following error ( as below image) in the create part UI after performing the steps.
In the site.xconf the following had been added
<Property name="wt.part.WTPart" overridable="true" targetFile="codebase/com/ptc/core/rule/server/delegate/init/RuleConfigurableTypeAttribute.properties"
value="number,name,lifeCycle,lifeCycle.id,teamTemplate,teamTemplate.id,folder.id,organization.id,COMPONENT_CATEGORY,Customer,Description,Manufacturer 1,Manufacturer Part No 1,PROJECT_NUMBER,ROHS Compliance,Project Name"
" Need to hide ROHS Compliance "
In theOIR the following had been added
<AttrConstraint id="ROHS Compliance" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</AttrConstraint>
Hello Uthayan Sir,
How r u ?
i need your help to solve this issue.
it is possible to rehost the Windchill 8.0M040 from "testplm.ttrpune.com" to "tatatoyoplm.tachogroup.com"
Vivek Uchekar
9850879590
