How To Generate Reports In Windchill
kchaithanya
Hi All,
Good Day To You..
I want to generate reports in Windchill  as per Product wise, year wise etc.
I've installed business reporting for 10.2 M030 and could able to open Cognos in  browser.
I'm struggling for generating reports as doing this for first time.
Need steps  to perform this task.
Thanks In Advance
Krishna Chaithanya.
Any working Windchill User ID  will work fine for cognos admin user.
The value used for the wt.cognos.namespace property must match the Namespace ID value in the Cognos Configuration tool, which by default is AdministrativeLDAP. If you have changed the Namespace ID value, then you must use that new value for the wt.cognos.namespace property.
It is worth reading through - http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCInstall_WCBusinessReportPostInstall&action=show
Binesh Kumar
Barry Wehmiller
10 REPLIES 10
Windchill OOTB Cognos reports are available in Context > Reports. If it is a product, Product > Reports. When you have Cognos installed, the reports will run on Cognos in the backend and display the results. If you don't have Cognos, then basic HTML page will get displayed.
If you want to create custom report, Report Management Utility is place where you create reports - http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=QBReportMgrAbout&action=show . There are a lot of existing reports shared by the user community   You can download and import the reports to your system.
If you want to create reports and run it through Cognos from Windchill. Follow - https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS148905
Binesh Kumar
Hi Binesh,
Thanks For Your Response
Actually, I want to create a report and run it through Cognos from Windchill.
As you mentioned, I've created a sample report through  Windchill site -> Utilities->Report Management and exported it as QML on my desktop.
Opened Cognos through URL and launched report studio but there I'm unable to find any import option to import already exported QML.
Please  suggest me for this.
Thanks And Regards
Krishna Chaithanya
As you mention it is 10.2 M030. you have to update the  WBR fix patch. the run the following commands to load the reports.
run into shell
1. windchill com.ptc.windchill.enterprise.report.ReportHelper modelupdate
2.  windchill com.ptc.windchill.cognos.CognosProxy loadreports <WindchillHome>\loadFiles\cognosReports\pdml
3.  windchill com.ptc.windchill.cognos.CognosProxy loadreports <WindchillHome>\loadFiles\cognosReports\wnc
4. ant -f <Windchillhome>/installer/wnc/wbr_actions.xml
5. Clear the windchill and browser cache --> Restart the windchill
Lavish Sharma
After creating report/QML you have to run below command so that your QML will be available in Congons  > Report studio >  Importable objects tab (in source)
once your report is available in congos then Use the Toolbox tab to add a varietyof objects to the report i.e. Image, Tables , Hyperlinks.etc…
Hope  it helps!!!
Shreyas
Hi Shreyas,
The above mentioned command is resulting  error.
Look for detailed error in Method Server and cogserver.log
From my notes -
Review the bellow in wt and db.properties. We should ensure that the username and password for cognos admin is right as well
  • wt.auth.trustedHostswt.auth.trustedHosts
  • wt.cognos.namespace  should be set to AdministrativeLDAP
  • wt.cognos.endpointUrl
  • wt.cognos.externalUrl
  • wt.cognos.admin.password
Binesh Kumar
Barry Wehmiller
Actually I've given Windchill admin password when it prompts as I'm not getting Cognos admin password(I've lost it)
Also Ive noticed from db.properties that wt.cognos.namespace is set to Windchill , but the actual ldap properties are seems to be different. Please check below screen shots.
Binesh Kumar
Barry Wehmiller
Hi All,
I'm now able to generate reports in Cognos.
I've run above mentioned activities in Windchill and did some changes in site.xconf and finally achieved it.
Thanks to all of you for quick response and suggestions which really helped alot
Krishna Chaithanya
Hi Krishna,
Can you mark the appropriate answer as correct,to help others in the community.
Bhushan
