How can I disable cache in embedded chromium?
mschimanski
2-Explorer
I'm trying to debug an Application for the Chromium browser, but the cache is enabled. How can I disable it? The Apache modules mod_header and mod_expires have no effect. Does anyone have an idea?
Thanks and best regards
Michael
6 REPLIES 6
In  chrome, I think the cache can be disabled only when DevTools is open. In DevTools > Settings > Disable Cache. I have also tried the extension CacheKiller and it worked.
Thank you
Binesh Kumar
Barry Wehmiller
I have persuaded Apache. The embedded chromium works fine.
Many thanks
Michael
Thank you
Binesh Kumar
Barry Wehmiller
How do you get to DevTools in the embedded chromium browser?
syadala
(To:RandyJones)
Hi Randy Jones,
         Here is the screen shot.
Sudhakar
RandyJones
20-Turquoise
(To:syadala)
Sudhakar Yadala wrote:
Hi Randy Jones,
Sudhakar
That is not the embedded chromium browser. That is the (standalone) Chrome browser.
Mat
(To:mschimanski)
Hi there,
I have the same problem.
The solution describes with "dev tools" in Chrome seems to have no effect on embedded browser.
@ptc: How Do You think can a developer debug his/hers code, if the "compiler" ignores any changes?
