Do you know if there is an API for synchronize the workspace of a user?
We had a customization that modify an EPMDocument in the commonspace, and we want to syncrhonize its copy in the user workspace, for let the user see the modification in real time without synchronize the workspace by himself.
Does anyone know how to do that?
I'm not sure which versions of Windchill or Creo you are using, but based on CS61420 this is not currently supported. This would make a good Idea, though. 🙂
