How can i find Windchill Demo data for POC and setup guide
JA_13802817
3-Newcomer
Windchill 개념 증명(POC)을 실행해야 합니다. 이전에는 "데모 카탈로그"라는 곳에서 데이터를 구할 수 있었는데, 더 이상 이용할 수 없는 것으로 알고 있습니다. 혹시 데모 데이터를 가지고 계신 분이 있다면 공유해 주시면 감사하겠습니다.
그리고
Windchill의 기본 설정부터 최종 설정까지 모든 내용을 다루는 종합 설치 가이드를 어디에서 찾을 수 있을까요?
고객센터에서 받은 설치 가이드는 너무 복잡합니다. 더 자세한 자료가 있다면 공유해 주시면 감사하겠습니다.
You can refer to the following link for free 3D data.
https://grabcad.com/library
You can download the files, open them in Creo, and then check in them into Windchill.
Regarding the VM installation, have you checked with your internal system admin or infra team?
5 REPLIES 5
Hi @JA_13802817,
If you did not load the demo data while installing the Windchill application, you can refer to the following article to install the demo data.
https://www.ptc.com/en/support/article/CS348830?source=search
If you are planning to install Windchill, the following article will be helpful.
https://www.ptc.com/en/support/article/CS44937?source=search
JA_13802817
3-Newcomer
(To:TDT)
Thank you for your reply.
For the demo data,
I need 3D Creo data, drw, frm, asm, prt, and template. I've already checked the links you provided, but they're a bit different from what I'm looking for.
My goal is to install Windchill on a VM and then practice configuring it using Creo data.
I referred to the installation guide, but the explanations are too complicated. Is there a separate guide or summary that clearly explains the VM installation process?
Thank you for your help, but I apologize for the many requests.
Thank you.
BenLoosli
(To:JA_13802817)
Installing Windchill on a VM is no different than a physical machine.
There are many things that need to be setup after the Windchill software is installed. Each setup can be tailored to your company's requirements. What I use at one company may not be what you need at your company. The community can help with actual questions, just try to be specific in what you are asking for.
Is there a way to view ECAD data created in different CAD formats in 3D within Windchill?
And
The company seeking a POC is in the electrical and electronics sector.
This company creates and manages 2D drawings using AutoCAD and ZW CAD, using a 1:N format. In this case, what efficient way can we manage these drawings? Is 1:1 management with 3D data possible?
