windchill
AL_10371359
windchill
Version: Windchill Below 11.0
Use Case: start of Windchill User Interface
Description:
I have a small issue with starting Windchill, I tried to find the solution alone today but I can’t, I have the following error message:2026-02-02 15:57:36,162 ERROR [wt.intersvrcom.SiteMonitor.timer] wt.intersvrcom.SiteMonitor - Names=[master], URL=http://tls-vsrvdcns19.marc.fr.ssg:81/Windchill/servlet/WindchillGW, Status=SITE NOT RESPONDING, ResponseSeconds=1.003, TimeOfPing=2026-02-02 15:57:33.149 +0100
16 REPLIES 16
Hi @AL_10371359,
Is your Method Server instance Started?
If so, could you please share the Method Server logs?
If it is not Started, could you instead provide the Server Manager logs?
AL_10371359
(To:TDT)
Yes the method server is launched,
See Methode Server.log
Thanks for your help
Best Regards,
Albert
I do not see any Method Server logs attached.
AL_10371359
(To:TDT)
I will copy it it in my mail:
2026-02-03 09:58:45,526 INFO [main] wt.system.out - ------------------------------------------------------
2026-02-03 09:58:45,531 INFO [main] wt.method.server.startup - Starting MethodServer
2026-02-03 09:58:45,533 INFO [main] wt.method.server.startup - JVM id: 3584
2026-02-03 09:58:45,533 INFO [main] wt.method.server.startup - JVM: Oracle Corporation, Java HotSpot(TM) 64-Bit Server VM, 1.7.0_72 (24.72-b04), 64-bit
2026-02-03 09:58:45,533 INFO [main] wt.method.server.startup - OS: Windows Server 2008 R2, amd64, 6.1
2026-02-03 09:58:45,534 INFO [main] wt.method.server.startup - Host: TLS-VSRVDCNS19 (tls-vsrvdcns19.marc.fr.ssg)
2026-02-03 09:58:45,534 INFO [main] wt.method.server.startup - java.rmi.server.hostname: tls-vsrvdcns19.marc.fr.ssg
2026-02-03 09:58:45,537 INFO [main] wt.method.server.startup - wt.rmi.server.hostname: paloma.marium.int
2026-02-03 09:58:45,537 INFO [main] wt.method.server.startup - HeapDumpPath: E:\PTC\Windchill_10.2\Windchill\heapDumps
2026-02-03 09:58:45,538 INFO [main] wt.method.server.startup - Class path =
E:\PTC\Windchill_10.2\Windchill\codebase
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\commons-configuration-1.9.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\Gantt.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\GanttExplorer.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\ieWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\install.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\mksapi.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\mpmlWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\reqlWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\restWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\rialtoWeb.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\RMWebServices.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\TwxIEWebService.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\WebArtWSClient.jar
E:\PTC\Windchill_10.2\Windchill\codebase\WEB-INF\lib\wncWeb.jar
E:\PTC\Windchill_10.2\Windchill\lib\mpml.jar
E:\PTC\Windchill_10.2\Windchill\lib\pdml.jar
E:\PTC\Windchill_10.2\Windchill\lib\reql.jar
E:\PTC\Windchill_10.2\Windchill\lib\servlet.jar
E:\PTC\Windchill_10.2\Windchill\lib\wnc.jar
E:\PTC\Windchill_10.2\Java\lib\tools.jar
E:\PTC\Windchill_10.2\Windchill\tomcat\bin\bootstrap.jar
E:\PTC\Windchill_10.2\Windchill\tomcat\bin\tomcat-juli.jar
E:\PTC\Windchill_10.2\Windchill\srclib\wnc\WtAsmAgent.jar
2026-02-03 09:58:45,539 INFO [main] wt.method.server.startup - WTContext time zone set to Europe/Paris; offset: 1.0
2026-02-03 09:58:45,539 INFO [main] wt.method.server.startup - Setting default time zone to GMT; offset: 0.0
2026-02-03 09:58:46,217 INFO [main] wt.pom.properties - wt.pom.maxDbConnections= 15
2026-02-03 09:58:46,217 INFO [main] wt.pom.properties - wt.pom.minDbConnections= 5
2026-02-03 09:58:46,217 INFO [main] wt.pom.properties - wt.pom.dbConnectionsHardLimit= 20
2026-02-03 09:58:46,217 INFO [main] wt.pom.properties - wt.pom.dbConnectionsSoftLimitWaitTime= 0
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.dbConnectionsWaitTime= 0
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.connectionCloserThreshold= 0
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.connectionCloserIdleTimeout= 0
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.connectionMonitorSleepInterval= 10
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.lostConnectionCodes=
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.recoverableConnectionCodes= 0,28,1012,17002,17008,6005
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.freeConnectionImmediate= false
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.maxIdleStatementCaches= 0
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.jdbc.driver= com.microsoft.sqlserver.jdbc.SQLServerDriver
2026-02-03 09:58:46,218 INFO [main] wt.pom.properties - wt.pom.jdbc.url= jdbc:sqlserver:
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.jdbc.host= tls-vsrvdcns19.marc.fr.ssg
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.jdbc.port= 1433
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.jdbc.service=
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.jdbc.database= wt10
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.dbUser= wt10
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.dbSchemaUser= wt10
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesNameList=
2026-02-03 09:58:46,219 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesValueList=
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.dbConnectionRetryCount= 80
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.userDefinedFunctionsFileName= E:\PTC\Windchill_10.2\Windchill\db\userDefinedFunctions.xml
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.rowPrefetchCount= 20
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.statementCacheSize= 50
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.cachedStatementReuseLimit= 50
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.feedbackInterval= 500
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.interruptInterval= 50
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.cachedStatementRSLimit= -1
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.implicitTransactions= true
2026-02-03 09:58:46,220 INFO [main] wt.pom.properties - wt.pom.implicitTransactionsRollbackTime= 600
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.navigateDepthThreshold= 4
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.navigateDepthUnionLimit= 10
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.queryDepthThreshold= 3
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.queryDepthInClauseSizeLimit= 300
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.lobChunkSize= 32528
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.log.JDBCStatements= false
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.log.fileJDBC= null
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.log.filterJDBC= null
2026-02-03 09:58:46,221 INFO [main] wt.pom.properties - wt.pom.chunk.defaultSize= 300
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.objectReferenceQuerySize= 254
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryChunkSize= 500
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryArrayTableEnabled= false
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.inflateHint= RULE
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.inflateSingleTableMode= true
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.useBind= true
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.inClauseFixedSize= 5
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.inClauseSizeLimit= 1000
2026-02-03 09:58:46,222 INFO [main] wt.pom.properties - wt.pom.inClauseBindLimit= 300
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.inClauseUseBindOptimization= true
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationThreshold=50
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationTempTableUsePrimaryKey=true
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationCardinality=-1
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.cardinalityValueFixedSize= 100
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.queryBindLimit= 2100
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.tempTableNumberPerThreshold= 5
2026-02-03 09:58:46,223 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeNumberOfThreshold=3
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeThresholdValues=200,1000, 2000
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.tempTable.insertChunkSize=50000
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.startupQueryLimit= -1
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.queryLimit= -1
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.paging.queueInvokeTime= 600
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.paging.sessionCleanupTime= 1800
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.paging.threshold= -1
2026-02-03 09:58:46,224 INFO [main] wt.pom.properties - wt.pom.paging.insertChunkSize= 250
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.paging.fetchLimit= 15
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.paging.fetchSleepInterval= 1000
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.paging.closeSleepInterval= 600
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.paging.snapshotQueryLimit= -1
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.paging.pagingSessionLimit= 5
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.statementCache.summaryInterval= 2000
2026-02-03 09:58:46,225 INFO [main] wt.pom.properties - wt.pom.enableNLSSort= false
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.constantArrayTableLimit= 4000
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.traceTiming.enable= true
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.blobRead.handle620LV= false
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.blobRead.handleOldLV= false
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.blobRewrite.enabled= false
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.selectForUpdateEnabled= false
2026-02-03 09:58:46,226 INFO [main] wt.pom.properties - wt.pom.refreshCache.enabled= true
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.refreshCache.summeryInterval= 0
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.refreshCache.size= 200
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.enableSQL99OuterjoinSyntax= true
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.enableInListOptimizationWarning= false
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.chunkThreshold=-1
2026-02-03 09:58:46,227 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.roleChunkSize=-1
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.objectChunkSize=-1
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.refIntegrity.removeOids.objectChunkSize=-1
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.batch.spec.tableExpressionThreshold=-1
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.batch.spec.useTableType= true
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.batch.spec.useColumnList= true
2026-02-03 09:58:46,228 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.classChunkSize= 2000
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.chunkSize= 5000
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.dispatchEvents= false
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.retry.enable= false
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.closePreparedStatement.threshold=-1
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.insert.chunkSize= 100000
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.batch.update.chunkSize= 100000
2026-02-03 09:58:46,229 INFO [main] wt.pom.properties - wt.pom.combineOrSubSelectExpressions= true
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.emptyTableQueryClassChunkSize = 400
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.emptyTableQuery.excludedSourceClassNames = wt.fv.master.MasteredOnReplicaItem,wt.fv.FvItem,wt.fv.FvMountValidatorLock
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.maxQueryRetryCount= 5
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.pdsDecoderBypassUserLoader = true
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.oracle.blobExplictOpen.enable= false
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.oracle.blobInlineWriteThreshold= -1
2026-02-03 09:58:46,230 INFO [main] wt.pom.properties - wt.pom.oracle.disableAlwaysSemiJoin= true
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.oracle.jdbcConnectionMemoryLimit= 48
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.oracle.nlssort.truncateLength= 600
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.size = 7
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.queueSize = -1
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.implicitEnabled=false
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.externalTableValidSchemaNames = null
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.pdsHandleByteAsShort = true
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - wt.pom.useExplicitTimezoneForJDBC = false
2026-02-03 09:58:46,231 INFO [main] wt.pom.properties - Windchill DataStore: SQLServer
2026-02-03 09:58:46,232 INFO [main] wt.pom.properties - Windchill DataStore is not cluster
2026-02-03 09:58:46,232 INFO [main] wt.pom.properties - JDBC Driver Version: major=4 minor=0
2026-02-03 09:58:46,372 INFO [main] wt.method.server.startup - MethodServer created - port 5003: MethodServerImpl[UnicastServerRef2 [liveRef: [endpoint:[tls-vsrvdcns19.marc.fr.ssg:5003,wt.util.WrappedRMISocketFactory@81e4a1,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[-332b1041:19c22b9c2b8:-7ffc, 6429516133168417821]]]]
2026-02-03 09:58:46,381 INFO [main] wt.util.WTPropertiesWatcher - wt.properties being watched at: E:\PTC\Windchill_10.2\Windchill\codebase\wt.properties
2026-02-03 09:58:46,607 INFO [main] wt.method.server.startup - Starting services - class = wt.services.StandardServicesHandler
2026-02-03 09:58:50,523 INFO [main] wt.pom.properties - wt.pom.delete.triggerClassNames=
2026-02-03 09:58:50,523 INFO [main] wt.pom.properties - wt.pom.delete.bypassReferentialIntegrityClassNames=wt.iba.value.ReferenceValue,wt.iba.value.AbstractContextualValue
2026-02-03 09:58:59,183 INFO [main] wt.util.version.WindchillVersion -
Timestamp: février 03, 2026 - 8:58:59 (GMT: 3 févr. 2026 08:58:59)
Support Support Installer
Datecode Release Number Release Id Sequence Display Label
M030-CPS25 10.2 pdml.10.2.30.25.07 01 PTC Windchill PDMLink 10.2
M030-CPS25 10.2 wsp.10.2.30.25.07 01 PTC Windchill 10.2 Service Pack
M031 Creo 3.0 vizpviewrun.10.2.31.00.40 03 PTC Creo View - Clients
M030-CPS25 10.2 mpml.10.2.30.25.07 01 PTC Windchill 10.2 MPMLink
M030 10.2 whc.10.2.30.00.39 01 PTC Windchill 10.2 Help Center
M032 Creo 3.0 vizadapters.13.2.32.00.01 04 PTC Creo View - Adapters
M030-CPS25 10.2 ie.10.2.30.25.07 01 PTC Windchill 10.2 Info*Engine
M030-CPS18 10.2 solr.10.2.30.18.04 01 PTC Windchill 10.2 Index Search
M030-CPS25 10.2 commonpdm.10.2.30.25.07 01 PTC Windchill 10.2 Common Base
M030-CPS24 10.2 wlp.10.2.30.24.01 01 PTC Windchill 10.2 MultiLanguage Pack
M030-CPS25 10.2 wnc.10.2.30.25.07 01 PTC Windchill 10.2 Services
Patches:
Label Description Install Date
paloma.v2016.05 Patch for Paloma Version v2016.05 [Seq 00] 4 mai 2016 08:45:23
paloma.v2.4.1.2 Patch for Paloma Version v2.4.1.2 [Seq 00] 12 mai 2017 12:23:43
paloma.v2.4.1.4 Patch for Paloma Version v2.4.1.4 [Seq 00] 19 mai 2017 08:32:21
paloma.v2.4.1.5 Patch for Paloma Version v2.4.1.5 [Seq 00] 23 mai 2017 08:14:23
paloma.v2.4.1.6 Patch for Paloma Version v2.4.1.6 [Seq 00] 29 mai 2017 12:54:12
paloma.v2.4.1.7 Patch for Paloma Version v2.4.1.7 [Seq 00] 2 juin 2017 06:57:34
paloma.v2.4.1.9 Patch for Paloma Version v2.4.1.9 [Seq 00] 16 juin 2017 08:03:20
paloma.v2.4.1.11 Patch for Paloma Version v2.4.1.11 [Seq 00] 22 juin 2017 13:39:41
paloma.v2.4.2.1 Patch for Paloma Version v2.4.2.1 [Seq 00] 26 sept. 2017 07:40:46
paloma.v2.4.3.17_ImportPI Patch for Paloma Version v2.4.3.17_ImportPI [Seq 00] 30 avr. 2019 15:15:48
paloma.v2.4.4.4 Patch for Paloma Version v2.4.4.4 [Seq 00] 28 mai 2019 13:17:29
paloma.v2.6.2.0 Patch for Paloma Version v2.6.2.0 [Seq 00] 13 janv. 2026 06:38:33
paloma.v2.6.3.0 Patch for Paloma Version v2.6.3.0 [Seq 00] 15 janv. 2026 08:05:17
Non-Default Locale Support:
Code Name
fr
2026-02-03 09:58:59,461 INFO [main] wt.pom.properties - Connection: datastore=Microsoft SQL Server(10.50.1617) jdbcVersion=4.0 driver=Microsoft JDBC Driver 4.0 for SQL Server(4.0.2206.100) driverVersion=4.0
2026-02-03 09:59:03,000 INFO [main] wt.fv.info - Last generated value of STREAMID_SEQ 479901
2026-02-03 09:59:03,001 INFO [main] wt.fv.info - Last generated value of FILENAMEUSN_SEQ 472701
2026-02-03 09:59:03,037 INFO [main] wt.fv.info - max(streamid) from tables = 235239
2026-02-03 09:59:03,042 INFO [main] wt.fv.info - max(uniqueSequenceNumber) from tables = 228039
2026-02-03 09:59:08,040 INFO [main] wt.fv.info - Creating secret key.
2026-02-03 09:59:08,062 INFO [main] wt.fv.info - Secret key generated successfully.
2026-02-03 09:59:08,155 INFO [main] com.ptc.windchill.counterpart.StandardCounterPartService - CounterPart service: started with classification not checked out
2026-02-03 09:59:08,256 INFO [main] wt.wvs.workeragent.StandardCadAgentService - Démarrage de l'agent CAO de WVS
2026-02-03 09:59:08,291 ERROR [CadAgent] wt.wvs.workeragent.CadWorkers - The executable of PROE worker(s) on tls-vsrvdcns02.ad.cimpa.corp (worker 1) does NOT match any of the trusted prefixes.
2026-02-03 09:59:08,339 ERROR [CadAgent] wt.wvs.workeragent.CadConnection - Impossible de se connecter au port 5 600
2026-02-03 09:59:08,340 ERROR [CadAgent] wt.wvs.workeragent.CadConnection - L'agent CAO est peut-être déjà actif.
2026-02-03 09:59:08,341 ERROR [CadAgent] wt.wvs.workeragent.CadConnection - Address already in use: JVM_Bind
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:376)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:376)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at java.net.ServerSocket.<init>(ServerSocket.java:128)
at com.ptc.wvs.server.cadagent.CadConnection.connect(CadConnection.java:61)
at com.ptc.wvs.server.cadagent.CadAgentServer.run(CadAgentServer.java:134)
at wt.session.SessionThread.run(SessionThread.java:225)
2026-02-03 09:59:08,399 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Starting LoadLogicRepositoryTask.run()
2026-02-03 09:59:08,441 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Starting initTypeDefinitions()
2026-02-03 09:59:09,179 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Finished initTypeDefinitions()
2026-02-03 09:59:09,179 INFO [main] com.ptc.core.logic.LogicRepository - Logic Repository processing started
2026-02-03 09:59:16,028 INFO [main] wt.pom.statementCache.summary - StatementCache: wt.util.Cache%664736297 [size=50, count=50, hits=2000, misses=178, overflows=96]
2026-02-03 09:59:16,391 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - DATATYPE MISMATCH:
2026-02-03 09:59:16,392 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - type = WCTYPE|wt.part.WTPart
2026-02-03 09:59:16,393 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - attribute = organizationReference
2026-02-03 09:59:16,393 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - datatype = com.ptc.core.meta.common.TypeInstanceIdentifier
2026-02-03 09:59:16,394 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - mapping = orgid
2026-02-03 09:59:16,394 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - ATI = WCTYPE|wt.part.WTPart~MBA|masterReference^WCTYPE|wt.part.WTPartMaster~MBA|organizationReference^WCTYPE|wt.org.WTOrganization~SCA|organizationIdentifier
2026-02-03 09:59:16,394 ERROR [main] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - ATI datatype = java.lang.String
2026-02-03 09:59:22,079 INFO [main] com.ptc.core.logic.LogicRepository - Logic Repository processing completed
2026-02-03 09:59:22,084 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Finished LoadLogicRepositoryTask.run()
2026-02-03 09:59:22,110 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started initializeXML()
2026-02-03 09:59:23,332 INFO [main] wt.method.server.startup - Classification Service started successfully.
2026-02-03 09:59:25,872 INFO [WfUserWorkQueue.PoolQueue] wt.system.out - >> Thread pool sized for WfUserWorkQueue is 12
2026-02-03 09:59:26,331 INFO [exportToGPAO.PoolQueue] wt.system.out - >> Thread pool sized for exportToGPAO is 12
2026-02-03 09:59:26,494 INFO [forumEventPropogationQueue.PoolQueue] wt.system.out - >> Thread pool sized for forumEventPropogationQueue is 12
2026-02-03 09:59:26,593 INFO [WfPropagationQueue.PoolQueue] wt.system.out - >> Thread pool sized for WfPropagationQueue is 12
2026-02-03 09:59:26,936 INFO [test9.PoolQueue] wt.system.out - >> Thread pool sized for test9 is 12
2026-02-03 09:59:26,948 INFO [test8.PoolQueue] wt.system.out - >> Thread pool sized for test8 is 12
2026-02-03 09:59:26,960 INFO [DeleteCompletedWorkItemsQueue.PoolQueue] wt.system.out - >> Thread pool sized for DeleteCompletedWorkItemsQueue is 12
2026-02-03 09:59:27,079 INFO [commonScheduleQueue.SchedulingThread] wt.pds.passwordexpiry.PasswordExpiryWarningService Administrator - Datastore password expiry warnings will commence 15 days in advance of expiration. (Configurable via property: wt.pds.passwordExpirationChecking.days)
2026-02-03 09:59:27,463 INFO [main] wt.method.server.startup.services - Tous les gestionnaires ont démarré.
2026-02-03 09:59:27,463 INFO [main] wt.method.server.startup - Le service StandardManagerService a démarré.
2026-02-03 09:59:27,464 INFO [main] wt.method.server.startup - Services started.
2026-02-03 09:59:27,505 INFO [commonScheduleQueue.SchedulingThread] wt.pds.passwordexpiry.PasswordExpiryWarningService Administrator - Datastore password has no expiration.
2026-02-03 09:59:27,524 INFO [main] wt.method.server.startup - MethodServer registered with ServerManager
2026-02-03 09:59:27,525 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap
2026-02-03 09:59:27,531 INFO [main] wt.method.server.startup - Creating wt.method.WTAdapter
2026-02-03 09:59:27,540 INFO [main] wt.method.server.startup - Creating wt.method.ClusterMonitor
2026-02-03 09:59:27,559 INFO [main] wt.method.server.startup - Creating wt.method.jmx.Startup
2026-02-03 09:59:27,708 ERROR [WindchillAdapter-Initializer] wt.adapter.WTAdapter - unexpected initialize error, will not retry.
java.net.UnknownHostException: tls-vsrvdcns19.ad.cimpa.corp
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$1.lookupAllHostAddr(InetAddress.java:901)
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1293)
at java.net.InetAddress.getAllByName0(InetAddress.java:1246)
at java.net.InetAddress.getAllByName(InetAddress.java:1162)
at java.net.InetAddress.getAllByName(InetAddress.java:1098)
at java.net.InetAddress.getByName(InetAddress.java:1048)
at com.infoengine.util.NetUtils.isLocal(NetUtils.java:75)
at com.infoengine.au.SocketAccess.getServiceAddresses(SocketAccess.java:418)
at com.infoengine.au.SocketAccess.initialize(SocketAccess.java:315)
at com.infoengine.au.SocketAccess.<init>(SocketAccess.java:243)
at wt.method.WTAdapter$1.run(WTAdapter.java:203)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
2026-02-03 09:59:29,007 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.methodServer.info - JVMName=3584@TLS-VSRVDCNS19,
StartTime=1770109123903,
MaxHeapBytes=1062207488,
ServiceName=MethodServer,
JVMArguments=[-javaagent:E:\PTC\Windchill_10.2\Windchill\srclib\wnc\WtAsmAgent.jar,
-Xverify:none,
-Djava.endorsed.dirs=E:\PTC\Windchill_10.2\Windchill\lib\endorsed,
-Djava.awt.headless=true,
-Djava.rmi.server.useCodebaseOnly=true,
-Dwt.manager.serviceName=MethodServer,
-Dwt.logs.dir=E:\PTC\Windchill_10.2\Windchill\logs,
-Dcom.sun.management.jmxremote,
-Djmx.remote.protocol.provider.pkgs=wt.jmx.remote.protocol,
-Duser.language=fr,
-Duser.region=FR,
-Dlog4j.configuration=WEB-INF/log4jMethodServer.properties,
-Xdebug,
-Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend=n,
-Dwt.tomcat.embeddedMode.enable=true,
-Xms1086m,
-Xmx1086m,
-XX:PermSize=170m,
-XX:MaxPermSize=450m,
-XX:InitialCodeCacheSize=25m,
-XX:ReservedCodeCacheSize=128m,
-XX:ParallelGCThreads=2,
-Xloggc:E:\PTC\Windchill_10.2\Windchill\logs\MethodServer-260203095843718-1-GC.log,
-XX:+PrintGCDetails,
-XX:+PrintGCDateStamps,
-XX:+UseGCLogFileRotation,
-XX:GCLogFileSize=128m,
-XX:NumberOfGCLogFiles=4],
AvailableProcessors=4
2026-02-03 09:59:30,426 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=3584@TLS-VSRVDCNS19, HeapMemoryUsage=196932016, NonHeapMemoryUsage=131690872, Uptime=46522, ProcessCpuTime=66066423500, JITCTime=35030, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[1432,932], GCCount=[2,16], Classes=16888, Threads=114, TotalStartedThreadCount=190, PermGenPercentCollUsage=25.254104614257812, PermGenPercentUsage=25.255691528320312, CodeCachePercentUsage=9.328651428222656
2026-02-03 09:59:30,458 INFO [main] wt.method.server.startup - Creating wt.phonehome.queue.PhoneHomeQueueScheduler
2026-02-03 09:59:30,483 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap$WaitUntilStarted
2026-02-03 09:59:30,565 INFO [commonScheduleQueue.SchedulingThread] wt.fv.info Administrator - StandardFvService.deleteFvItemsInChunk : Deleting unreferenced FvItems :: []
2026-02-03 09:59:31,311 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Finished initializeXML()
2026-02-03 09:59:43,754 INFO [localhost-startStop-1] wt.system.err - f?vr. 03, 2026 8:59:43 AM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextInitialized
2026-02-03 09:59:43,755 INFO [localhost-startStop-1] wt.system.err - INFOS: WSSERVLET12 : initialisation du processus d?coute de contexte JAX-WS
2026-02-03 09:59:45,305 INFO [localhost-startStop-1] wt.system.err - f?vr. 03, 2026 8:59:45 AM com.sun.xml.ws.server.MonitorBase createRoot
2026-02-03 09:59:45,306 INFO [localhost-startStop-1] wt.system.err - INFOS: Metro monitoring rootname successfully set to: com.sun.metro:pp=/,type=WSEndpoint,name=/Windchill-TwxIEWebServiceImplService-TwxIEWebServiceImplPort
2026-02-03 09:59:45,556 INFO [localhost-startStop-1] wt.system.err - f?vr. 03, 2026 8:59:45 AM com.sun.xml.ws.server.MonitorBase createRoot
2026-02-03 09:59:45,557 INFO [localhost-startStop-1] wt.system.err - INFOS: Metro monitoring rootname successfully set to: com.sun.metro:pp=/,type=WSEndpoint,name=/Windchill-RMWebServicesImplService-RMWebServicesImplPort
2026-02-03 09:59:45,584 INFO [localhost-startStop-1] wt.system.err - f?vr. 03, 2026 8:59:45 AM com.sun.xml.ws.transport.http.servlet.WSServletDelegate <init>
2026-02-03 09:59:45,588 INFO [localhost-startStop-1] wt.system.err - INFOS: WSSERVLET14 : initialisation du servlet JAX-WS
2026-02-03 09:59:45,870 INFO [localhost-startStop-1] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization started
2026-02-03 10:00:02,137 INFO [localhost-startStop-1] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization completed in 16266 ms
2026-02-03 10:00:02,171 INFO [Servlet engine main] com.ptc.tomcat.embedded.Bootstrap - Servlet engine ready; catalina.base=E:\PTC\Windchill_10.2\Windchill\tomcat\instances\instance-8010
2026-02-03 10:00:02,173 INFO [main] wt.method.server.startup - MethodServer ready (in 78.27 secs).
The logs indicate that the Method Server is ready.
Could you please clarify what issue you are referring to?
AL_10371359
(To:TDT)
The user interface does not start, please find the hard copy of screen bellow:
And where are you running this client, from the Windchill server or from a client?
You are certain the port is 81 and not the default 80?
Is Apache running?
What does this URL return?
The windchill UI (User Interface) is only used locally on the server.
Yes Apache is running
The url http://tls-vsrvdcns19.marc.fr.ssg:81 returns:
Look in E:\PTC\Windchill_10.2\HTTPServer\config.properties
for...
HTTPS_ENABLED=false
HTTPS_PORT=443
HTTP_ENABLED=true
HTTP_PORT=??
ServerName=?? (should be tls-vsrvdcns19.marc.fr.ssg)
Confirm you can ping tls-vsrvdcns19.marc.fr.ssg
Confirm it is listening on the HTTP_PORT
from Powershell: tnc tls-vsrvdcns19.marc.fr.ssg -Port 81
From a Windchill shell:
xconfmanager -d wt.webserver.port
xconfmanager -d wt.webserver.protocol
xconfmanager -d wt.webapp.name
My answers:
HTTPS_ENABLED=false
HTTPS_PORT=443
HTTP_ENABLED=true
HTTP_PORT= 81
ServerName= paloma.marium.int
Yes the serverName is tls-vsrvdcns19.marc.fr.ssg, it is a VM (Virtual Machine with OS = Window Server)
The command tns does not work: upload_-aW1hZ2UwMDEucG5n-6656284231159813796..png
From the Window shell on the server:
windchill -d wt.webserver.port does not work: upload_-aW1hZ2UwMDIucG5n-8324473377539130165..png
-d is unknown action
windchill -d wt.webserver.protocol does not work: upload_-aW1hZ2UwMDMucG5n-3923035975112206342..png
windchill -d wt.webapp.name does not work: upload_-aW1hZ2UwMDQucG5n-1451276966456342122..png
Sorry, my bad.
The Powershell command is 'tnc' (test network connection), not 'tns'.
The Windchill shell commands are 'xconfmanager -d', not 'windchill -d'.
I just updated the commands in my previous response.
But I believe your smoking gun is the Apache server name.  It hasn't been rehosted.  Apache thinks it is 'paloma.marium.int' and Windchill thinks it is 'tls-vsrvdcns19.marc.fr.ssg'.
Rehost Apache.
pushd %WT_HOME%\..\HTTPServer
ant -f config.xml reconfigure -DServerName=tls-vsrvdcns19.marc.fr.ssg
Validate the configuration is 'OK'.
%wt_home%\..\HTTPServer\bin\httpd.exe -t
Restart Apache and try the URL again.
Apache works good: upload_-aW1hZ2UwMDEucG5n-5174149978380941371..png
It does not work: upload_-aW1hZ2UwMDEucG5n-4806540121306626738..png
Sanity check... What is the expected URL?
Where is your "SITE NOT RESPONDING" error in the log?
This appears to be a monolithic Windchill instance.  Why are there different values for Host, java.rmi.server.hostname, and wt.rmi.server.hostname?
Whatever your Windchill alias is, that should be the value of wt.rmi.server.hostname.
Ensure the values match and that the server can be pinged by this name if not a cluster or split domain reverse proxy.
https://www.ptc.com/en/support/article/CS68827
https://www.ptc.com/en/support/wnc-publishing-troubleshooter/initial-publishing-setup/cad-worker-start-up-failure/error-message-Executable-Not-Safe-when-starting-workers?source=search?sol_id={49358357-1941-47A1-B04A-FB8277B8433B}
Looks like there might be an issue in your adapterservice.json file, or a missing hosts file mapping.
