How do I disable automatic part numbering?
mrossman
3-Newcomer
We are importing cad files into PDMLink for a project which will modify an existing design, and we want to maintain the numbering scheme used by the old project. How do I disable the auto generated part numbers in PDMLink 10.1.
Our company currenlty doesn't have any trained admins so I need the dumbed down version, PDMLink is installed on Red Hat Enterprise Linux 6.2.
Thanks for the help.
KD
(To:mrossman)
In OIR for your part change the Attribute constraint for number like this
<AttrConstraint id="number" algorithm="wt.rule.algorithm.BooleanBranch" ignore="false" force="false" final="false">
<Value algorithm="com.ptc.core.rule.server.impl.IfContainerTypeEqualsProjectTest"/>
<Value algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
</Value>
<Value algorithm="wt.rule.algorithm.BooleanBranch">
<Value algorithm="wt.rule.algorithm.StringEqualsTest">
<Attr id="endItem"/>
<Arg>true</Arg>
</Value>
<Value algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</Value>
</Value>
</AttrConstraint>
KD
(To:mrossman)
</Value>
<Arg>true</Arg>
</Value>
</Value>
</Value>
</AttrConstraint>
