We just installed windchill 9.1 M010 on solaris 10. I setup ssl as per the advanced configuration guide. When I access PDMLink I get prompted to logon. What also happens is that when I select a link that runs a java applet I get a second prompt for my credentials. After that everything runs fine and there are no other logon prompts. How do I set up ssl so that I only have to login once?
Thanks for the feedback!!
Unfortunately, we've disabled the 'Remember Password" checkbox in ie. But I haven't performed the import you mentioned (the configuration guide makes no mention of that), I'll trythat.
