How do i change an inherited attribute's contraint?
slaw
8-Gravel
Hello all,
This may have already been posted somewhere, but I could not find anything on it.
I have performed a subtype of Part in the Types and Attribute Manager.  I now have two issues that I cannot resolve.
1) I need to use the attribute "Default Unit" - Internal Name (defaultunit), however, the legal value list is cannot be changed from "ea|as_needed|kg|m|l|sq_m|cu_m" and I need it to be "ea|as_needed|in|ft|oz|lbs|kg|m|l|sq_m|cu_m".
2) I need to add the attribute "Organization" - Internal Name (orgid).  The users need this information to associate the parts with where they are coming from - internal/vendor.
I know Part is a modeled type and Default Unit is inherited but the legal value list does not meet our needs.  Is there a way to modify it in some way.  I have tried adding another legal value list in constraints to override the existing one, but it did not work.
Any help would be greatly appreciated.
Thank you,
Steven
slaw
8-Gravel
(To:slaw)
I filed a ticket with PTC and was given an answer.
1. From Windchill shell, run enumcustomize
2. Navigate to wt/part/QuantityUnitRB.RB.ser from enumcustomize dialog box, open it
3. Add a new entry
4. Ensure the Selectable box is checked
5. Click Save and Continue on Build Resource dialog box 4. Exit from enumcustomize
5. From Windchill shell run: ant -f codebase\Makejar.xml
6. Clear the Tomcat cache
7. Restart Windchill server
I am posting this in case anyone else ever needs to do this.
Steven
