Hello, i have been trying to load into my workspace a old version of a part but i cant do it. I already tried to select the version of the part and selecting Add to workspace and then selecting the drop down to change the config spec. to "as stored and lastly making sure the Dependents is set to "required". but it doesnt loads the old version but the new. Any idea on how to do it?
Im using windchill release 12.0.2.5 and PTC CREO Parametric.
Hi @CH_10756211
Create new workspace
Go to the 3D Part detail page go to the history
Select previous iteration from the table - click on the
Click on the Actions and use Add to workspace
you should see following warning
Press OK
Then you should find older iteration in your workspace
PetrH
would you try the steps , in article https://www.ptc.com/en/support/article/cs343790
Hi @CH_10756211
Press OK
PetrH
You may be able to download an older iteration or version, but you probably can NOT check it out. Windchill default settings can prevent older version/iterations from being checked out.
yes you right, we need to enable below preference to do so :
