How java code to create WTDocument from template in Project Content
vostapenko
It posible to create WTDocument from Template from same Project?
Create Java Class ext.tpolis.WTDocumentHelper.java
package ext.tpolis;
import java.util.ArrayList;
import wt.content.ContentHelper;
import wt.content.ContentHolder;
import wt.doc.WTDocument;
import wt.enterprise.TemplatesUtility;
import wt.fc.PersistenceHelper;
import wt.fc.ReferenceFactory;
import wt.folder.FolderHelper;
import wt.folder.FolderingInfo;
import wt.inf.container.WTContainer;
import wt.inf.container.WTContainerRef;
import wt.util.WTException;
import wt.vc.VersionControlHelper;
* @author Ostapenko Vitaliy
* @version 1.0
public class WTDocumentHelper {
* getDocumentTemplate
* Return Template WTDocument of WTContainerRef
public static WTDocument getDocumentTemplate(String paramDocTemplateName, WTContainerRef paramDocTemplateContainerRef){
WTDocument docTemplate = null;
ReferenceFactory refFact = new wt.fc.ReferenceFactory();
try {
ArrayList asd = wt.doc.WTDocumentHelper.service.getTemplates(paramDocTemplateContainerRef);
for(int i = 0; i < asd.size(); i++){
String[] tpl = (String[]) asd.get(i);
if (tpl[1].equals(paramDocTemplateName)){
docTemplate = (WTDocument) refFact.getReference(tpl[4]).getObject();
break;
//Get latest revision of template
docTemplate=(WTDocument) VersionControlHelper.service.getLatestIteration(docTemplate, true);
if (docTemplate==null)
throw new WTException("Not found WTDocument Template :" + paramDocTemplateName);
} catch (WTException e) {
e.printStackTrace();
return docTemplate;
* createDocumentFromTemplate
* Return WTDocument create from Template
public static WTDocument createDocumentFromTemplate(String paramDocName,String paramDocTemplateName, WTContainer paramDocContainer) throws WTException {
WTDocument doc = null;
WTContainerRef contRef = WTContainerRef.newWTContainerRef(paramDocContainer);
try {
WTDocument docTemplate = getDocumentTemplate(paramDocTemplateName,contRef);
doc = WTDocument.newWTDocument();
doc.setName(paramDocName);
doc.setTypeDefinitionReference(docTemplate.getTypeDefinitionReference());
doc.setContainerReference(contRef);
doc.setDomainRef(paramDocContainer.getDefaultDomainReference());
doc.setFormat(docTemplate.getFormat());
PersistenceHelper.manager.save(doc);
//Copy primary content file from Template
ContentHelper.service.copyContent((ContentHolder) docTemplate, (ContentHolder) doc);
//Rename primary content file
doc = (WTDocument)TemplatesUtility.setFilename((WTDocument)doc);
} catch (Exception e) {
return doc;
Compile Class.
Put WTDocumentHelper.class in to %WT_HOME%\codebase\ext\tpolis
In Template Workflow create Expression and add java code:
wt.doc.WTDocument document = (wt.doc.WTDocument)primaryBusinessObject;
wt.inf.container.WTContainer container = document.getContainer();
// Set Doc Name
String paramDocName = "TestDoc";
// Set Doc Template Name that is locate in Project
String paramDocTemplateName = "Test Template";
wt.doc.WTDocument docFromTemplate = null;
try{
docFromTemplate= ext.tpolis.WTDocumentHelper.createDocumentFromTemplate(paramDocName, paramDocTemplateName, container);
}catch (Exception e) {
Then in Project run Route Document after finish WfProcess in folder /Default of Project was created TestDoc from Document Template.
7 REPLIES 7
KD
(To:vostapenko)
Try below code to create WTDocument using template.
  1. 1. First we have to write this class TemplateHelper.java
package ext.ptc;
import java.io.InputStream;
import com.ptc.windchill.enterprise.doc.server.DocumentUtility;
import com.ptc.windchill.enterprise.templates.TemplatesFactory;
import wt.admin.AdminDomainRef;
import wt.content.ApplicationData;
import wt.content.ContentServerHelper;
import wt.doc.DepartmentList;
import wt.doc.DocumentType;
import wt.enterprise.EnterpriseHelper;
import wt.enterprise.SequenceGenerator;
import wt.inf.container.WTContainerHelper;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.util.WTProperties;
public class TemplateHelper {
* return the WTDocument object basis the template name
* @param templateName
* @param orgName
* @throws Exception
public static WTDocument getDocumentTemplate(String templateName, String orgName) throws Exception
QuerySpec qs = new QuerySpec(WTDocument.class);
SearchCondition templateNameSC = new SearchCondition(WTDocument.class,WTDocument.NAME,
SearchCondition.EQUAL,templateName);
qs.appendWhere(templateNameSC, new int[]{0,1});
WTContainer container = WTContainerHelper.service.getByPath("/wt.inf.container.OrgContainer="+orgName).getReferencedContainer();
System.out.println("Cont Name in getDocTemp ==>"+container.getName());
wt.fc.QueryResult qrTemplates = EnterpriseHelper.service.getTemplates(container,
qs, null, true, true, true);
if(qrTemplates.hasMoreElements())
return ((WTDocument)qrTemplates.nextElement());
else
return null;
2. Later we have to give these inputs pertaining to specific document subtype wherever it is getting created:
In my scenario, I was adhering document template of subtype ‘Commercial proposal document’ for organization ‘PTC’ where ‘Commercial Proposal Document’ Is the name of the Template.
  1. cmpDOC.setDomainRef(doc.getDomainRef());
WTDocument docTemplate = TemplateHelper.getDocumentTemplate("Commercial Proposal Template", "PTC");
System.out.println("Document Template Name : - "+docTemplate.getName());
doc=(WTDocument) VersionControlHelper.service.getLatestIteration(doc, true);
System.out.println("childDoc Name : - "+doc.getName());
PersistenceHelper.manager.save(cmpDOC);
wt.content.ContentHelper.service.copyContent((wt.content.ContentHolder)docTemplate, (wt.content.ContentHolder)cmpDOC);
Kaushik
vostapenko
(To:KD)
If I Run Java class return:
(wt.pom.pomResource/4) wt.pom.ObjectNotPersistentException:
Object "wt.doc.WTDocument" is not constant.
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:795)
at wt.services.ServiceFactory$ClientInvocationHandler.invoke(ServiceFactory.java:349)
at com.sun.proxy.$Proxy11.copyContentItem(Unknown Source)
at ext.tpolis.Test.main(Test.java:147)
KD
(To:vostapenko)
Try from Processor or WorkFlow.
Remotely it'll through error.
And change the template name and organization name as per your requirement.
Kaushik
vostapenko
(To:KD)
Create Test WFProcess with my custom method and initialize.
WtDocument Create, bat without any primary content.
package ext.tpolis;
* @version 1.0
try {
break;
return docTemplate;
try {
return doc;
Compile Class.
// Set Doc Name
try{
bcedar
(To:vostapenko)
Ran across this while trying to do the same thing.  Ended up using a lot of what was said here with the addition of using EnterpriseHelper.  With this I didn't need ContentHelper at all and it'll maintain the Save-As History accurately (which is what create from template does through the UI, it seems).
here's the code
public class DocumentHelper {
     * not sure what's going on here. got the code from...
     * https://community.ptc.com/t5/Windchill/How-java-code-to-create-WTDocument-from-template-in-Project/m-p/432582#M50927%3F&art_lang=en&posno=2&q=service.copyContent&source=search
    public static WTDocument getDocumentTemplate (String paramDocTemplateName, WTContainerRef paramDocTemplateContainerRef)
        ReferenceFactory referenceFactory = new ReferenceFactory();
        try {
            ArrayList templatesList = WTDocumentHelper.service.getTemplates(paramDocTemplateContainerRef);
            for (int i = 0; i < templatesList.size(); i++)
                String[] templateProperties = (String[]) templatesList.get(i);
                if (templateProperties[1].equals(paramDocTemplateName))
                    docTemplate = (WTDocument)referenceFactory.getReference(templateProperties[4]).getObject();
                    break;
            docTemplate = (WTDocument)VersionControlHelper.service.getLatestIteration(docTemplate, true);
            if (docTemplate == null)
                throw new WTException("Not found -> WTDocument Template: " + paramDocTemplateName);
        return docTemplate;
    public static WTDocument createDocumentFromTemplate(String paramDocName, String paramDocTemplateName, WTContainer paramDocContainer) throws WTException
        WTContainerRef containerRef = WTContainerRef.newWTContainerRef(paramDocContainer);
        try {
            WTDocument docTemplate = getDocumentTemplate(paramDocTemplateName, containerRef);
            doc = (WTDocument)EnterpriseHelper.service.newCopy((RevisionControlled)docTemplate);
            doc.setContainerReference(containerRef);
            doc = (WTDocument)EnterpriseHelper.service.saveCopy((RevisionControlled)docTemplate, (RevisionControlled)doc);
            doc = (WTDocument)TemplatesUtility.changeFilename((WTDocument)doc);
        return doc;
I don't necessarily like using code I don't fully understand... the getDocumentTemplate for example.  Before I go to production I might end up changing that function to using the PersistanceHelper.find method of getting it.
bcedar
(To:bcedar)
Didn't like using some of the logic that I didn't understand, so I redid a bit of this code.
    public static WTDocument getDocumentTemplate (String paramDocTemplateName) throws WTException
        QuerySpec wtDocTemplateSpec = new QuerySpec(WTDocument.class);
        wtDocTemplateSpec.appendWhere(new SearchCondition(WTDocument.class, WTDocument.NAME, SearchCondition.EQUAL, paramDocTemplateName), new int[] {0});
        wtDocTemplateSpec.appendAnd();
        wtDocTemplateSpec.appendWhere(new SearchCondition(WTDocument.class, "template.templated", SearchCondition.IS_TRUE), new int[] {0});
        wtDocTemplateSpec.appendWhere(new SearchCondition(WTDocument.class, "template.enabled", SearchCondition.IS_TRUE), new int[] {0});
        QueryResult wtDocTemplateSpecResult = PersistenceHelper.manager.find((StatementSpec)wtDocTemplateSpec);
        if (wtDocTemplateSpecResult.hasMoreElements())
            docTemplate = (WTDocument)(wtDocTemplateSpecResult.nextElement());
            docTemplate = (WTDocument)VersionControlHelper.service.allVersionsOf(docTemplate).nextElement();
        return docTemplate;
    public static WTDocument createDocumentFromTemplate(String paramDocName, String paramDocTemplateName, WTContainer paramDocContainer) throws WTException, WTPropertyVetoException
        WTDocument docTemplate = getDocumentTemplate(paramDocTemplateName);
        doc = (WTDocument)TemplatesUtility.setFilename(doc);
        return doc;
