How to Expand ECN Comments View Text Box
zgodula
11-Garnet
We use the comments field on New Change Tasks to write lengthy descriptions on each object that will be changed on the ECN.
Out of the box, this field is quite small and only displays a partial view of the text that is entered.  This makes it hard to proofread comments and view formatting.
Is there anyway to make this text box bigger so that more of the text is visible?
We are on Windchill 11.0 M20.
Thanks in advance for any suggestions.
10 REPLIES 10
JHall
(To:zgodula)
@zgodula
Don't know if you ever got helped, but Wrap Text is available and probably will solve your issue.  Select the pull down arrow on any column and select Wrap Text.
James
STEVEG
(To:JHall)
@JHall
I believe @zgodula is talking about when editing the Task.  Not in one of the tables on the details page of the change.
I do not believe this can be done but this is one of my peeves about a change.  Why does PTC think that small box is all we need?
JHall
(To:STEVEG)
@STEVEG
Ugh, I don't know, but I tend to complete my comment in a notepad window, cut and paste it into that ridiculously small box.  I wish it could be expanded as each user wanted.
Jams
zgodula
11-Garnet
(To:STEVEG)
@STEVEG
Correct, hopefully this will be fixed in a future release.
STEVEG
(To:zgodula)
@zgodula There is a "Was this information helpful" dialog.  I selected no and said it doesn't work.  Maybe you can do the same?
zgodula
11-Garnet
(To:STEVEG)
Good call, done.
@STEVEG @zgodula  Hey , are there any updates or workarounds for this feature in Windchill 12.1?
I am still on 12.0 and planning to go to 12.1.
I suspect this may be related to this known issue:
https://www.ptc.com/en/support/article?n=CS214887
Nope.  That doesn't work.
