How to Get Physical Vault File size for each iterated CAD Document in a particular lifecycle state on each Product containter
WindchillAdmin
2-Explorer
I think there is a command line tool that can be leveraged, but I usually prefer SQL query. The key is joining the EPMDocument table to the ApplicationData table.
Is something like this sufficient for the information you're looking for?
select
edm.cadname,
ed.versionida2versioninfo as rev,
ed.iterationida2iterationinfo as iter,
(ad.filesize/1024) as filesize_KB,
prod.namecontainerinfo as product_name
from
applicationdata ad,
holdertocontent htc,
epmdocument ed,
epmdocumentmaster edm,
pdmlinkproduct prod
where
ad.ida2a2=htc.ida3b5
and htc.ida3a5=ed.ida2a2
and ed.ida3masterreference=edm.ida2a2
and ed.ida3containerreference=prod.ida2a2
and ad.role='PRIMARY'
and ed.statestate='PRODUCTION'
order by
edm.cadname;
10 REPLIES 10
select
edm.cadname,
from
applicationdata ad,
epmdocument ed,
pdmlinkproduct prod
where
order by
edm.cadname;
Thanks a Lot.
It is exact what i expected.
I am trying the estimate size for doing Windchill Purge activity. Can you help me in getting same data except last revision.
That is where it starts to get complicated. You'll need the maximum of ed.versionsortida2versioninfo from the query above. At this point, it might be easier to put it into Query Builder. Or perhaps someone else in the community can help.
In this document Resource for reporting there is a query builder to catch EPMDocs size.
You can modify it for your needs.
Marco
Dear Ben Perry ,
can you clarify, why the below 2 query output differs. I am fetching epmdocuments with INWORK Status. why Query1 and Query 2 output differs.
Query 1 :
select
count (*)
from
applicationdata ad,
epmdocument ed,
pdmlinkproduct prod
where
and ed.statestate='INWORK'
output : 238563 rows selected
Query 2 :
select count(*) From epmdocument where statestate='INWORK'
output : 449569 rows selected
There could be a number of different reasons for the difference, but we can start with this...
Query 1 is only getting EPMDocuments that are located in Product containers. You mentioned that was your original specification. Query 2 is getting EPMDocuments from everywhere - Products, Libraries, and Projects (if applicable).
oh. Great.
Which table hold the Library , Project list.
As i am planning to do a windchill purge for the first time, i am doing this exercise to collect how much space occupied by EPM Documents on all products, libraries & projects. And planning to purge only EPM Documents which is under ÏN-WORK State to free some space from Vault.
I noticed from your 1st query that entire vault files are located in applicationdata table and whichever file name refers CAD_NAME it linked to a epmdocument .
And other than CAD_NAME , i could see more files and space occupied by *.ol than CAD_NAME . when this .ol file getting generated, is that anyway to clear this type of files, since this .ol file type occupies by 70% of vault space.
In order to get library and project files, replace the PDMLINKPRODUCT with WTLIBRARY and PROJECT2 tables.
Can you share your SQL where you see the .ol files? FYI...You can switch to Advanced Editor when you're replying, and then highlight the SQL code that you paste in the reply window, and then format it as code using the >> Syntax Highlighting > SQL option on the toolbar.
Great.
.ol files found in applicationdata table. details below
select filename,description,filesize,role from applicationdata;
sample output :
FileNameDescriptionFileSizeRole
4223456_5.olBBOX -0.0365 -0.0363979 0 0.0365 0.0363979 0.002 M14539SECONDARY
4223456_6.olBBOX -0.399832 -0.2225 -0.152006 0.367999 0.2225 0.00239103 M562553SECONDARY
4223456_7.olBBOX -0.015 -0.019 -0.0149746 0.015 0 0.0149746 M26430SECONDARY
4223456_8.olBBOX -0.2085 -0.0749955 0 0.2085 0.075 0.028 M75779SECONDARY
4223456_9.olBBOX -0.03575 -0.0205 -0.081 0.03575 0 0.081 M28327SECONDARY
4223456.jpg 3295THUMBNAIL
4223456.pvt 23588THUMBNAIL3D
023A_34m.jpg 2702THUMBNAIL
023A_34m.pvt 7101THUMBNAIL3D
023A_34m.log 378SECONDARY
023A_34m.olBBOX -0.3913 -0.00552726 -0.0362 0.3782 0.203019 0.4532 M206691SECONDARY
autocad.pvs 273PRODUCT_VIEW_ED
Go to the information page in Windchill for 4223456. Navigate to the Content tab, and view the Attachments table. Is there anything listed there?
Else, if nothing is listed there, then is 4223456 an assembly? And 023A_34M is a component maybe? I think these are actually publish files. If so, then I think they will also be deleted along with the actual EPMDocument. I've never done it, so can't say for sure, but seems like that would be the case.
