How to LocalizedMessage from ResourceBundle file using code ?
ManikandanVelay
I have on requirement like ,in which I need to get Localized Message of Partusage Quantity (form wt.part.QuantityUnitRB) in OOTB Key values like ea,kg ..
How to get Dispaly value using code ?
I am not able to find right method from wt.util.WTMessage class
String resourceBundle = wt.part.QuantityUnitRB.class.getName();
String key = "ea"; // or "l" or "kg" or "as_needed", etc.
String localizedName = wt.util.WTMessage.getLocalizedMessage(resourceBundle, key);
Hi Patrick
Actually there is no wt.part.QuantityUnitRB.class file only .SER file is available in windchill.
How to get value from .SER file
Just drop the "RB" from the class name in the example Patrick gave you. *RB.rbInfo files compile into *.class files.
String resourceBundle = wt.part.QuantityUnit.class.getName();
Thanks Patrick & Matthew.
Thank you. I'd give Patrick the Correct and me the Helpful though. 🙂 He did the work for ya, I just happened to run across the thread.
