Any inputs on adding a "Actor" role in team template xml file..
tried the below scenerio but failed to add the role.
<!DOCTYPE NmLoader SYSTEM "standard12_0.dtd">
<NmLoader>
<csvTeamTemplateBegin handler="wt.team.LoadTeam.createTeamTemplateBegin">
<csvname>Doc Owner Team</csvname>
<csvdescription>Doc Owner Team</csvdescription>
<csvfolderLocation>/System</csvfolderLocation>
<csvenabled>true</csvenabled>
</csvTeamTemplateBegin>
<csvRoleHolder2 handler="wt.team.LoadTeam.createRoleHolder">
<csvroleToAssign>OWNER</csvroleToAssign>
<csvassignedPrincipal/>
</csvRoleHolder2>
<csvActorHolder2 handler="wt.team.LoadTeam.createActorHolder">
<csvassignedActorRole>Creator</csvassignedActorRole>
</csvActorHolder2>
<csvTeamTemplateEnd handler="wt.team.LoadTeam.createTeamTemplateEnd"/>
</NmLoader>
Hi ,it is certainly failing with uniqueness exception , this is expected the createTeamTemplate, it is only for creating it does not update existing .
if this not the case , what is the error shown in logs
it should be:
