How to change the standards calculations
ptc-6573014
I created my system tree in the software, but the failure rate of the assemblies in chain are sum, for example: Assembly 1-> Assembly 2
The FR of Assembly 1 is the sum of assembly 2 and the components associated to Assembly 1. But i don't want this, I need that the FR of Assembly 1 to be just the sum of the components. How can I do that?
Anderson,
I have the same problem many times.
Just create artificial sub-assemblies in that level and position where you want to have this kind of sum.
