How to check family table Instance & generic using modelcheck ?
I'm not too familiar with modelcheck myself, but I found this article regarding modelcheck and family tables/generics. Does this article answer your question?:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28324
Haris, was Chris' article helpful? What exactly are you trying to check with modelcheck? Are you needing it to check something in relation to Windchill? If not, then this question may be better off answered by someone in the Creo forum.
Yes .The article was helpful & got my requirement.
Thanks a lot.
