We use Design View and Plant View for WTPart. and attach specification document to both views -- as design view and plant view could be different spec.
When promoting the specification document to release, it would collect related WTPart in the promotion process. However, it would only collect the latest one revision of object -- i.e., not the latest of Design and Plant view revision but latest one either Design or Plant view depending which one was modified latest. Even if manually collect both views in to promotion form, it says promotion can only deal with one version of object, and hence for me to choose between the Design View or Plant View.
Obviously the users do not like it, as they can only promotion one view with the spec doc revision (likely design view), and have to go to individual plant view to manually attach the newly release spec. document.
wondering anyone else having the same problem.
We have been aware of this limitation since a while but it becomes a fair issue now from a user point of view. Having the ability collecting all views of a WTPart with their related objects would be a tremendous boost for our users.
