Hello Everyone,
I have test.war file, wanted to be deploy in windchill. how i can achieve this ??
I puted my test.war file in tomcat\webapps folder and restart the windchill but not working.
I'm not sure about the Tomcat bundled with Windchill, but if you have Tomcat installed standalone (like for ThingWorx), the Tomcat "Manager App" is used to deploy .war files.
Thanks Tom for the response provided, but i could not able to run tomcat separately in windchill, I want clear answer about how to deploy test.war file in windchill, and what configuration should be changed in web.xml to run file test.war file. And also specify the URL path in windchill after deploying the war file to run the app.
With the below steps you should be able to deploy a war
ant -f config.xml installWebApp-DappName=sample-DdocBase=/app01/windchill11/Windchill/tomcat/webapps/sample
3. Now you have two options either to enable direct HTTP access on tomcat to access the app or use web server directives direct the traffic to tomcat. if you want to enable
direct access add below line to /app01/windchill11/Windchill/tomcat/conf/server.xml.default
<Connector port="8080" protocol="HTTP/1.1"
connectionTimeout="20000"
redirectPort="8443" />
Now restart Windchill and access the page - http://localhost:8080/sample.
Binesh Kumar
Medtronic - MITG
