Hi to all!
Anybody know how to disable or hide tabs in CreoView when user whatching some document from Windchill (may be via properties bean or config files)?
You can control it through the configuration file.You can refer to this tech support article.
Hope that helps.
~Syed
Hello Anton,
What tabs you want to hide ?
Athmanand
Hi athmanand!
I want to disable print tab.
Hope that helps.
~Syed
