How to enable MPMLink explorers in actions menu in Windchill 11.1?
sa-5
8-Gravel
Hi All,
I am unable to find MPMLink explorers in actions menu in Windchill 11.1 M010. I could enable PSE from preference but not finding enabling preference for MPMLink explorers like MPSE and resource explorer. "Manufacturing Associative Part Structure Browser" is available in actions but not explorers. Any help is much appreciated. Thanks.
mfadel
(To:sa-5)
Hi ,
in the 11.1 M010 and later , the only exploerer available are the Product Structure Explorer and The SIM Explorer (Serive Product Structure Explorer )
For the MPM objects all utilities had been changed to use HTML , excpet the Gantt Explorer that is is still using Java applets .
Regarding the help center I agree with you that some page are still mentioning MPM explorers, that had been removed from the software .
Please open a TS call for that an an engineer will submit a documentation SPR in order to correct the help
BR,
Fadel
mfadel
(To:sa-5)
Hi ,
MPM Applets have been removed from Widnchill 11.1 and replaced by HTML browsers , I have created an Article for this topic in the past see https://www.ptc.com/en/support/article?n=CS284763
The below explorer are already removed in 11.1 M010
  • Process Plan Explorer :
  • Resource Explorer
  • MPSE
I hope this helps .
Fadel
sa-5
8-Gravel
(To:mfadel)
Thanks a lot for the update. But PTC help documents are still referring to Explorers for "Association of Plants" and other resource or MPM related topics. Can you guide if there are any updated help documents which could explain all topics and steps with the perspective of "Manufacturing Associative Part Structure Browser" ?
Thanks.
mfadel
(To:sa-5)
Hi ,
BR,
Fadel
The link you posted is wrong because has a space at the end.
This is the right link https://www.ptc.com/en/support/article?n=CS284763
Marco
