We are interested in knowing about a move from context action. This event gets stored in the database table AUDITRECORD. Can anyone shine a light on this how to extract meaningful data from it ? Thank you in advance. Regards, Bernard
Given any query builder report, you can get it to run automatically a few ways.
1. Save the report template with any needed criteria. Set up a "monitor" on the saved report with a schedule. Can even have the system email a link.
2. Run the query builder report from Excel - which just refreshes the data and makes use of any pivot tables, charts, etc. Set up how to get this automated using Excel tools.
The easiest option is to use audit purge reporting. You can also use SQLs to query this table - good thing is this table stores a lots of information - most of the cases you don't have to build complex joins. I don't think you can use report manager on this table - not sure have to check
Thank you
Binesh
Query builder reports can definitely pull all info from this table.
Notes:
"Purge" does exactly that - it pulls the rows out of the table and optionally stores them as rows in an .xml file as a WTDoc at Site level under Site, Folders.
You only can report on what has been collected in the auditrecord table; what is recorded is controlled by manually editing configaudit.xml. OTB, only a few things are recorded and they do not include Move actions.
Alright, I can derive valuable data from this. Do you know if you can automate this (having the xml saved to disk on a daily basis). I know that PTC is working on this, but I can't wait that long...
Hello Mike,
I wil try to go for the Query Builder solution, I used in the past with success to download attachments (dxf,iges, pdf,...).
Bernard
