How to get AuditRecord data from database
BernardWielfaer
We are interested in knowing about a move from context action. This event gets stored in the database table AUDITRECORD. Can anyone shine a light on this how to extract meaningful data from it ? Thank you in advance. Regards, Bernard
Given any query builder report, you can get it to run automatically a few ways.
1. Save the report template with any needed criteria.  Set up a "monitor" on the saved report with a schedule.  Can even have the system email a link.
2. Run the query builder report from Excel - which just refreshes the data and makes use of any pivot tables, charts, etc.  Set up how to get this automated using Excel tools.
5 REPLIES 5
The easiest option is to use audit purge reporting. You can also use SQLs to query this table - good thing is this table stores a lots of information - most of the cases you don't have to build complex joins. I don't think you can use report manager on this table - not sure have to check
Thank you
Binesh
Query builder reports can definitely pull all info from this table.
Notes:
"Purge" does exactly that - it pulls the rows out of the table and optionally stores them as rows in an .xml file as a WTDoc at Site level under Site, Folders.
You only can report on what has been collected in the auditrecord table; what is recorded is controlled by manually editing configaudit.xml.  OTB, only a few things are recorded and they do not include Move actions.
Alright, I can derive valuable data from this. Do you know if you can automate this (having the xml saved to disk on a daily basis). I know that PTC is working on this, but I can't wait that long...
Hello Mike,
I wil try to go for the Query Builder solution, I used in the past with success to download attachments (dxf,iges, pdf,...).
Bernard
