Hello friends,
I am looking for a query which can return me the CAD structure in windchill does some body know how we can achieve this. please see the screen shot
SELECT DISTINCT A0B.name ParentName,
A0B.documentNumber ParentNumber,
A2B.name ChildName,
A2B.documentNumber ChildNumber
FROM EPMDocument A0,
EPMDocumentMaster A0B,
EPMDocumentMaster A1,
EPMDocument A2,
EPMDocumentMaster A2B,
EPMMemberLink A3
WHERE (A0.idA3masterReference=A0B.idA2A2)
AND (A2.idA3masterReference=A2B.idA2A2)
AND ((A0B.name = 'ER00020039.asm'))
AND ((A3.idA3B5 = A1.idA2A2)
AND (A3.idA3A5 = A0.idA2A2)
AND (A2.idA3masterReference = A1.idA2A2));
Try this. It worked on my system to get level 1 CAD structure.
Thank you
Binesh Kumar
User epmmemberlink table to connect two epmdocuments. If you are looking for reference documents, use epmreference table
Thank you,
Binesh
Hi Binesh,
I try this but seems like not getting the accurate result
SELECT dM2.DOCUMENTNUMBER AS ASSEMBLY, M1.DOCUMENTNUMBER AS COMPONENT
FROM EPMDOCUMENT, EPMDOCUMENTMASTER M2, EPMMEMBERLINK, EPMDOCUMENTMASTER M1
WHERE EPMMEMBERLINK.IDA3B5 = M1.IDA2A2
and M2.DOCUMENTNUMBER = 'W10805805_CP01.PRT'
and EPMDOCUMENT.IDA3MASTERREFERENCE = M1.IDA2A2
GROUP BY M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER
order by M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER;
Could you try this one?
EPMDocument A0,EPMDocumentMaster A1,EPMDocument A2,EPMDocumentMaster A3,PDMLinkProduct A4,EPMMemberLink A5
A0.idA3masterReference = A1.idA2A2
A2.idA3masterReference = A3.idA2A2
A5.idA3B5 = A1.idA2A2
A5.idA3A5 = A2.idA2A2
Thank you
Binesh Kumar
nup it did not workout gives null values
A2B.name ChildName,
EPMDocument A2,
EPMMemberLink A3
Thank you
Binesh Kumar
It worked Thank ou so much Binesh
I am looking to do the same programatically.
Can anyone pls suggest relevant API to do the same.
Thanks in Advance..
